Pony electric start
Pony electric start
Showing 1 to 10 of 10 results
lil cat mec
Send a private message to lil cat mec
i saw this at a farm about 80mi from my place, we were picking up a military dodge power wagon
here is another way to run an electric start pony [attachment=24356]20140309_142854[1].jpg[/attachment][attachment=24357]20140309_142919[1].jpg[/attachment]
1935 CAT 22 2F4455W
1990 CAT D6H 4GG04120
2012 CAT 272C RED02823
1971? CAT 951B 86J01212
Sat, Jul 19, 2014 12:44 AM
bernie
My D42T had similar set up. Got fed up charging battery so pulled the contraption shortly after getting my machine. I'll never forget the charge I got hearing that starting engine fire up after using the rope for the first time.
I've wondered before if the pull rope spins the flywheel faster than a small electric motor for that initial impulse to the MAG.
Sat, Jul 19, 2014 3:48 AM
lil cat mec
Reply to bernie:
for speed, it would all have to do with gearing, that was the first time i have ever seen such a thing, i was facinated by it lol
1935 CAT 22 2F4455W
Sat, Jul 19, 2014 4:33 AM
biggastractor
Reply to lil cat mec:
Please tell us about the Dodge (and pics too)
Biggastractor
Sat, Jul 19, 2014 6:16 AM
lil cat mec
Reply to biggastractor:
Biggastractor
it was a weapons carrier, [attachment=24365]1901988_807057622657151_1593420498_n.jpg[/attachment]
this is the only picture i have of it, he sold it to his grandfather, whom now has 3 or 4... he also has a Gas CAT 60 with a spare motor, he has yet to start, 3 pull graders, a no.11 motor grader, etc... just to sum it up im jealous
1935 CAT 22 2F4455W
Sat, Jul 19, 2014 8:02 AM
ronm
I think my D2 has had something like that in the past-there's a battery tray on the fender & holes drilled right through the brass patent plate...:crazy:
Sat, Jul 19, 2014 8:49 AM
Kelly
And then again.
Kelly [attachment=24366]Baggs Cat_4.jpg[/attachment]
Sat, Jul 19, 2014 8:52 AM
Kurt Kocher
Send a private message to Kurt Kocher
Reply to Kelly:
And then again.
We have used an electric motor to start the pony engine. For some reason the older we get we seem to tucker out sooner.
Sat, Jul 19, 2014 9:21 AM
Thank you received: 59
Biggastractor
The one someone went to the most effort that I have seen was a RD6 where they had to make a pulley and hub to fit the shaft that you put the crank on and then the bracket to hold the starter on the radiator and then had starter button in the end of the pipe that was used to tighten the belt. We have had pictures of different variation of motors both gas and electric on the fender of D2 and D4 tractors here on this board over the years.And not being very good with carburetors or magnetos and having a pony that will sputter but will not take off and run I know why someone would build a makeshift starter.
Sat, Jul 19, 2014 9:30 AM
bernie
Reply to Ray54:
http://www.acmoc.org/bb/showthread.php?7904-Pony-motor-starter
Above is the link to post. Pics have been dropped. There were a few good ones as I recall.
Sat, Jul 19, 2014 11:51 AM
Jim Davis
Send a private message to Jim Davis
Reply to bernie:
Has anyone successfully removed the pony and coupled an air-cooled engine in its place? The coolant passages would have to be blocked and a gear setup made to run the pinion gears...
Sun, Jul 20, 2014 7:59 PM
| Kingaroy, Queensland
