D2 pushing snow in ontario can.
11 years 3 days ago #98114
by dan83
Heres some pics of the D2 pushing some snow away from our house the tracks are poor but it works im good at putting them back on ha
Thank you received: 13
Thank you received: 16
11 years 2 days ago #98137
by old-iron-habit
If you torch the oblong hole out of the center of the pads and make a set of snow pads out of them you will probably have better luck keeping them on even if they are well worn. There are some posts in the archives that show the holes for a guideline.
11 years 2 days ago #98139
by drujinin
Will allow the snow that is building up inside the Rails to push out as the Track goes around the Sprocket and the Idler. The snow would no longer lift the Rail off the Idler, this will help in Dirt also.
Thank you received: 678
11 years 2 days ago #98148
If I ever get to the stage of getting my D2 going, the "first" thing I'm going to do is make sure I can wind back the idler for track refitment purposes!
Thank you received: 84
11 years 2 days ago #98168
by mog5858
looks like you where having lost of fun there. you should really cut some snow holes in the pads it will let you spend more time pushing and less time getting back on track.
11 years 2 days ago #98172
by dan83
ha my track adjusters blew apart so i just use a bottle jack and a piece of pipe that i cut to fit over the old threaded rod so its pretty quick to get out and back in
Thank you received: 345
11 years 2 days ago #98191
by edb
Hi Dan,
you are lucky you have wide gauge unit or else you could have had your fuel transfer pump torn off by the track by now.
The pumps and the housing they mount to are hard to find down here in OZ for this reason.
I suggest you roughly make up something out of suitable sheet to help stop this happening. Does not have to be pretty just functional.
11 years 1 day ago #98197
by dan83
Thanks I have the belly pan off to do some work underneath her it stops them from getting over to far thanks though dan
Time to create page: 0.300 seconds
