D2 pushing snow in ontario can.
11 years 3 days ago #98114 by dan83
Heres some pics of the D2 pushing some snow away from our house the tracks are poor but it works im good at putting them back on ha
11 years 3 days ago #98116 by lil cat mec
looks like fun until the track came off!
1935 CAT 22 2f4455W
CAT 951
11 years 3 days ago #98119 by rustyfender
Replied by rustyfender on topic same snow
that snow looks familiar! same stuff we have in Wroxeter
11 years 2 days ago #98137 by old-iron-habit
If you torch the oblong hole out of the center of the pads and make a set of snow pads out of them you will probably have better luck keeping them on even if they are well worn. There are some posts in the archives that show the holes for a guideline.
11 years 2 days ago #98139 by drujinin
Will allow the snow that is building up inside the Rails to push out as the Track goes around the Sprocket and the Idler. The snow would no longer lift the Rail off the Idler, this will help in Dirt also.
11 years 2 days ago #98148 by neil
If I ever get to the stage of getting my D2 going, the "first" thing I'm going to do is make sure I can wind back the idler for track refitment purposes!
11 years 2 days ago #98168 by mog5858
Replied by mog5858 on topic nice
looks like you where having lost of fun there. you should really cut some snow holes in the pads it will let you spend more time pushing and less time getting back on track.
11 years 2 days ago #98172 by dan83
ha my track adjusters blew apart so i just use a bottle jack and a piece of pipe that i cut to fit over the old threaded rod so its pretty quick to get out and back in
11 years 2 days ago #98191 by edb
Replied by edb on topic Engine Side Covers
Hi Dan,
you are lucky you have wide gauge unit or else you could have had your fuel transfer pump torn off by the track by now.
The pumps and the housing they mount to are hard to find down here in OZ for this reason.
I suggest you roughly make up something out of suitable sheet to help stop this happening. Does not have to be pretty just functional.
11 years 1 day ago #98197 by dan83
Thanks I have the belly pan off to do some work underneath her it stops them from getting over to far thanks though dan
Time to create page: 0.159 seconds
