D8 Help
D8 Help
17 years 4 months ago #8825
by Packrat
Good morning;
Once again I need to tap the vast knowledge of the membership. My D8 15A763 suffered a broken forward-reverse shift lever (p/n 5H1818). It appeared to break because the clamp bolt broke. I've got the broken lever out but the broken bolt must be down in the transmission. I cannot find it with a flashlight and a magnet thru the shifter hole so I drained the oil in hopes that it would flush out. No luck, the inlet screen blocks the drain hole. My question is, can I remove the inlet screen thru the drain access hole? I've already removed the plate that includes the drain plug. The parts book shows the screen attached to an inlet tube that looks like it is removable fom outside the trans. I'll bet SJ has done this many times. Thanks.
Packrat
Thank you received: 821
17 years 4 months ago #8830
In looking through my parts book and service manual it does not state for sure that the suction bell and tube assembly will come out through the bottom opening but you can unbolt the assembly by removing the through bolts that pass through the front of the case. If you can't remove it it seems you would be able to at least move it out of the way to go bolt searching. Yes, it would be good if SJ or someone could actually verify.
17 years 4 months ago #8833
by Packrat
Thanks Old Magnet, I too saw the studs. I guess I'll just give it a try. Thanks again. Packrat
D8 Help
Time to create page: 0.136 seconds
