carburetor problems
17 years 3 months ago #8568 by chugwater crawlers
Here is one I need help on.
I have a 8C20 with an ensign carburetor. After I back the tractor off my trailer the engine starts running rough. It evens out if I choke it, but eventually I have to shut if off and readjust the high speed screw. Then it runs okay. It has plenty of gas in it. It does this every time it comes off the trailer.
Float sticking? Any thoughts? Thanks!
17 years 3 months ago #8569 by Chapter 3
Replied by Chapter 3 on topic Running rough
I had a tractor that did the same thing. Check the fuel tank and make sure that there is nothing floating around on the bottom covering the outlet to the carb.
17 years 3 months ago #8571 by ccjersey
Replied by ccjersey on topic carburetor problems
Trash in the carburetor float bowl or other fuel passage that is stirred up by the jostling of loading, travel and unloading.
I have a small portable welder that seems to have much the same trouble. I just expect to adjust the load needle most everytime I take it somewhere to weld something.
17 years 3 months ago #8572 by chugwater crawlers
I will try that. Chapter 3 this is you old tractor! Small world!
17 years 3 months ago #8584 by Cat-astrophe
Replied by Cat-astrophe on topic carburetor problems
Had the same problem, particularly when transporting the 15. Solved it by fitting a couple of inline fuel filters. The clear ones you can see thru. Most race shops / NAPA stock them.
Time to create page: 0.123 seconds
