The questions are at the bottom.
It must be the season for steering clutches. I've had to take mine apart since the clutch was engaged and wouldn't release. Oh now that is fun especially when you don't have a brakes on the same side, so I couldn't brake to turn right and there was no power to the drive to turn left.
Well I hobbled back to the shop by building up speed and slamming the good brake to turn one direction only. After tear down I found many interesting things:
1. Dirt was crammed up to the bottom of the clutch. This didn’t allow the cavity to breathe causing a multitude of problems.:
2. The lack of air cause a humidity issue which froze the adjusting nut on the brake, this caused the adjusting nut extension to brake off at the nut. (No Brakes):
3. The humidity caused the roller bearings, that pivot on the shaft for the clutch arms, to freeze in place so tight that I couldn’t move the arms to take them off. Could this be why my clutch wasn’t releasing to engage the final, hmmmm. Had to heat the arms up and pound the arms off of the bearing assembly.
4. Now it was time to remove the rivet that hold the shafts in place. Oh this should be easy the book said the shafts slide to THE REAR???
What do I do with the winch…Yes its always easier in black and white. After a lot of messing with the winch bolts, yes there are 8 not 6 like it appeared, we were ready to “slide the shafts out the rear” like the book said. I think this is the case if you don’t have rust holding everything near and dear. More heat to the case and with the help of the excavator to pull on the eye that was rigged to the threaded end of the shaft we managed to pull the whole tractor back, chalk the sprockets and try again. With much consternation the shafts slooowly slid out beating the roller bearings as we went. The book says the bearings should be replaced if worn, It doesn’t say they should be replaced if frozen SOLID so I guess I can keep using them hmmm.
5. Now came time to remove the bearing cage caps and lift the assembly out, after finding out that the 6” strap I was using wouldn’t let the bevel gear turn we manually pried the assembly up and out and then lifted it . That is when I found the hose for greasing the bearing was ripped out of the banjo fittings, I have yet to see that in the book
Ok, enough of the drama, my questions are:
A. Who do I get banjo fittings with the hose attached from?
B. Are the roller bearings an after market item and has anyone devised a way to lube them?
C. How about secondary breathers on top of the inspection plate?
D. Never-seize will solve the adjustment nut issue.
E. The shafts have some pitting will this be an issue?
F. And finally, gaskets, where do I get gaskets, the big one for the winch to tractor, the big one for the transmission/steering clutch cover, the bevel gear cover seal, along with smaller ones that if need be I could make.
Thanks for your time and hopefully help
CMD
