22 pilot bearing aftermarket part #
11 years 10 months ago #82272 by nw4evr
roller bearing , the one inside of flywheel disc... I have the cat numbers, but would anyone have the after market part numbers for inner, outer, and roller pieces?... I though i was ready to go together but i was advised that i better change the one i have or i will be sorry later on....
R2 5E 3542 SP, 22 2F, 22 1J
11 years 10 months ago #82273 by leon
Replied by leon on topic Leon
Post your Cat part no.and/or precise dim. as bearing may be aquired by size.
11 years 10 months ago #82276 by puffer@rpi.edu
Don't know what the non-CAT numbers are, but I got mine a couple months ago from my local CAT dealer.
Ray
11 years 10 months ago #82278 by edb
Replied by edb on topic Twenty Two Spigot Bearings
my 22 P/Book shows 1B3738 Bearing (outer race and Roller assembly) which is a Hyatt SC-403, made up of Hyatt parts outer race--SRA-403 and Roller Assem--OR-304.
The inner race is a V-226 or 0V0226 in new P/No format. Sorry have no equivelent for this.
It turns out that a 3J-5J D2 uses the same clutch outer spigot bearing Assem. whose inner race is a
4B3712--no cross given in my UMS Hyatt New Departure cross reference book.
It maybe that this race is only longer than the 22 needs--you would need to check dimensions here to be sure--only offering this as a possible aid to locating a suitable replacement--a bit if grinding would have you something that maybe available unless the above 0V0226 supercedes in the Cat system to something we can cross.
Hope this helps.
Time to create page: 0.141 seconds
