Cat Power Unit 4D1060
18 years 3 weeks ago #612
by kellyb
I have this engine that is from a Cat 44 pull type grader and it runs!! It is a single cyl. gas engine with a magneto and is air cooled. Its a heavy beast as it weighs 325 lbs.
Does anyone have one of these out there anywhere? Is it rare? I'll try and post a picture or 2 of it.
18 years 3 weeks ago #619
by kellyb
see attachment:
I have a better pic but this site asked me to reduce it to 800 x 1200 so this is the best I can do on short notice.
KB
Thank you received: 187
18 years 3 weeks ago #623
by josh
Book shows the 4d---- as a power unit, used on the 66 and 77 grader.
18 years 3 weeks ago #626
by kellyb
does your book give any specs such as HP, RPM, bore, stroke, etc. ?
also, anything on a governor, carb settings etc. Where can I find this info if not in your book?
Thanks!
Thank you received: 215
18 years 3 weeks ago #633
by bruce oz
hello kellyb ,the motor fitted to the 44 single frame grader in 1937 was the g800.
bore=3''5/8 stroke= 4'' , hp =5.5 @ 1300 rpm ,sorry this is the only info i have ,hope it helps ,bruce oz
18 years 3 weeks ago #636
by Kelly
Kellyb,
Bruce oz, Information is the same as mine. The only thing I would add is at Sn. 4D1196 a further refinement had been made to the grader engine which would assist in preventing the entrance of dirt into the engine. A new cylinder assembly had been provided, which could be used on all graders that completely enclose the valve push rods. Hope this is a little more help. Maybe someone will show up with some more information.
Kelly
18 years 3 weeks ago #644
by gwhdiesel75
Kellyb, I've been told that the engine is indeed sought after, because it is missing on many of the surviving No. 66 pull graders. GWH
18 years 3 weeks ago #654
by kellyb
to gw75 diesel,
I may be interested in selling it, yes, would the best way be to post it on this website?
or ebay it?
KB
Thank you received: 117
18 years 3 weeks ago #662
by OzDozer
The maintenance instructions for the single cylinder G800 engine (the smallest gas engine built by Cat), are found in the Operation and Maintenance Instructions booklet for the Power-Controlled #66 and #77 pull graders.
The OMI form number for the Power Controlled #66 grader, S/N 5E1-up, is 3226 .. and form number for the P.C. #77 grader, 9C1-up is 1663.
Time to create page: 0.186 seconds
