PV 15 Ensign carburetor question.
12 years 2 months ago #80028 by gary ca
These carburetors often have slight differences in the top cover. This one has a flat brass ring that rests in the larger collar of the top cover. You can see that it was peened to stay. The top covers I have seen do not have this second collar. The 2 holes in the ring line up with the 2 ports in the cover. It kinda looks like some kinda of baffle. No mention in my manual. Any thoughts on this piece? Thanks, G
12 years 2 months ago #80042 by hiwide15
Replied by hiwide15 on topic carb
I have seen in a ensign service letter where it said to leave this piece out when repairing ,It serves no purpose.
12 years 2 months ago #80060 by Mike Meyer
Replied by Mike Meyer on topic Interesting
I wonder how Chriscokid is getting on with the Ensign carby project, I've got a few old aluminum pots and pans I can send him for making the rubbish pot metal!:lol:
regards
Mike
12 years 2 months ago #80061 by WyoCat
That carb top is a low bowl design. Its shorter than the earlier design and requires a shorter metering body (center round piece). Most of these that I have seen were missing when I took those carbs apart. I am currently working with a pattern maker to be able to make these carb tops as cast reproductions.
Chad Enyeart
12 years 2 months ago #80078 by chriscokid
I am doing the same, Maybe we just need to work together then we would not have to both spend the full amount.
I have found out some very good news that will help the both of us.
Call me or send me an email and we will talk it over.
10 years 1 month ago #113241 by Mike Meyer
I was just looking through some old threads and saw this one, any progress on the 15 carb lid project?
Regards
Mike
10 years 1 month ago #113246 by hicrop10
If you two good fellows can come up with a replacement for these old carbs,all I can say is that may the sun always shine on you.The carbs have to be the biggest PIA to contend with on these old tractors.You no sooner think you have it running great and then the carb takes a crapper.I'ld like to find a good newer replacement for all of my tractors.Keep us all advised on your profess.Thanks.
10 years 1 month ago #113252 by rjh-md
I think that the bigest problem with the lides on these carbetors is the basic orginal design that the steel tubing connects to the lid ,and the viberation transferred from the tank and lines to the lid cause the lid to crack or threads stripping in the lid which holds the needle valve and seat.
The threads were stripped in the lid on my 15 ,and I solved the problem by chucking the lid in my lathe drilling out the top and tapping it to take the 9/16 NF thread of a Cat transmission test adapter .In turn I drilled out the test adapter to take a farmall ABC seat ,and needle valve which works on the orginal float .I also used rubber tubing from the supply valve under thhe tank to the carburetor to cut the vibration to the lid
This was done approximatly 10 years ago and the engine runs smooth
I would recommend that that any member with a 10 or 15 adapt a flexable hose to the carburetor to cut the viberation and stress to the lid
10 years 1 month ago #113296 by Pat in WI
Just the weight alone of the bronze fuel strainer was enough to crack those pot metal top covers. I solid mounted my strainer to take the load off and eliminate that risk.
Pat
Pat in WI
10 years 1 month ago #113579 by dadawg
I am also in need of a carb top for my fifteen, please keep us in the loop on reproductions.
Smitty
