Pony motor wont start
17 years 4 months ago #7611 by FarmerD5
My pony motor wont start but wont get no fire. Spark plugs are good. Can it be flooding or what?? I try to figure out what s wrong but still couldnt figure out. Any help will be greatly appreciated. Thanks
Thomas G Payne
17 years 4 months ago #7616 by gwhdiesel75
Replied by gwhdiesel75 on topic Pony motor wont start
Won't get any fire? Perhaps it is the magneto. Getting spark?
17 years 4 months ago #7617 by ccjersey
Replied by ccjersey on topic Pony motor wont start
If it's flooding, open the cylinder drains and let it blow out. Also check to see if the oil in it is diluted with gasoline, if so, change it now before you luck up and it starts and ruins itself due to the dilute oil.
Serious flooding,,,,,,,,,,, open up the carburetor and unstick the float and needle on the inlet from the tank.
How do you know the plugs are good if they won't fire? Ok,,,,,,,maybe they are new and that probably means they're good.
Take the kill wire loose on the mag to make sure that isn't the trouble. You can always cut off the fuel to stop it.
still no spark,,,,,,,,,,
clean and adjust the points in the mag to about 15-20 thousandths.
It should throw a spark about 3/8 inch to the block if you can spin it pretty good.
1-get the spark
2-get the fuel
3-got compression????
Still won't fire up, maybe swap wires on the mag cap just to check if someone got it backwards.
What's it in?
Time to create page: 0.133 seconds
