212 Motor Grader
212 Motor Grader
17 years 3 months ago #7394
by Brian Mann
Have an opportunity to pick up a very nice operating 212 Grader for less than scrap price. Need to know how much it weighs. Looks like a D2 motor. All replies are much appreciated.
Brian Mann
Thank you received: 803
17 years 3 months ago #7395
Range of 10,100 lbs to 13,730 lbs depending on model and whether it is single or tandem drive.
17 years 3 months ago #7399
by SJ
If it is a 9T then it would have the D311 engine like the D2 U series tractors has.
Thank you received: 10
17 years 3 months ago #7401
by ccjersey
check the powershaft to the controls before you buy. If the blade controls operate, the shaft is ok. Later models of the 9T had a shear pin to protect the shaft, earlier models didn't:eek:
If you buy it, check out the steering box early on, they are expensive and getting scarcer if you have to have one because your's bearings went out and you broke the worm (CAT want's $1200 for a new worm). I started to do ours, but incorrectly figured "if it ain't broke don't fix it"
We have one on it now that was adapted from a larger grader I belive.
17 years 3 months ago #7458
by Frank Fox
I have a 212 grader with a broken power shaft. Any one have one for sale?
I knew the shaft was broken when I purchased it, some one had replaced the shear pin with a grade 8 bolt, the rest is history
I would like any information on the steering box that was used on your 212,
So far my steering box is ok, but never know when it may go bad.
Frank
<a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
212 Motor Grader
