2T piston
2T piston
Thank you received: 28
5 months 1 week ago - 5 months 1 week ago #255936
by clayton
I have a 2T8780SP which should be a d4400 engine, the pistons I believe my be a little different as there is a top groove that doesn’t have a piston ring I have attached a few photos anyone know what the top groove does/ purpose? They are not a two piece piston either.
Last edit: 5 months 1 week ago by
clayton. Reason: Adding more
Thank you received: 27
5 months 1 week ago #255943
by ChrisE
I had the pistons out of a 2T I used to own and i can’t remember that top groove in them. It was more than 15 years ago i had it apart though so old timers disease might be kicking in. I am sure there were 3 compression rings and 2 oil rings i fitted to the pistons.
5 months 1 week ago #255944
by clayton
Well there is 3 compression rings and 2 wiper rings, the top groove doesn’t look big enough to take a ring. I have checked in the parts manual with no luck showing the groove.
5 months 1 week ago #255959
by ChrisE
That must be the design of the piston. Not sure why they would do that but the 3 compression rings are sufficient for proper engine operation. The boffins would have had a reason they designed them that way back in that era.
Thank you received: 214
5 months 1 week ago #255962
by Mike Meyer
RD4 pistons had 4 compression rings and 2 oil rings, same engine, just earlier version, quite possible a previous owner swapped in RD4 pistons after machining the ring lands under #1 ring land larger, to take larger rings from a later model D4400, and they decided 3 compression rings were enough, because by 1939, and the model D4 7J, Cat too had decided 3 compression rings were enough for that engine, they were learning all the time about their new diesel engines.
Just a theory, I'm usually wrong, but weird things were done back in the day by bush Mechanics to get a tractor running again ASAP.
Deebo
2T piston
Time to create page: 0.147 seconds
