D2 Oil Filter housing removal nut
5 months 2 weeks ago #255854
by btsclan
As my continuing saga of getting my 5U orchard model back into shape unfolds I yet again have come across an impasse.
I have a bad oil leak at the base of the oil filter housing, oil flows out very quickly when the main engine is turning. Looking at the parts manual I see its held down with a screw #9F6704, I need to remove the screw to fix the leak but the screws is at the bottom of the housing and cant get any sort of wrench down to take it off.
Would anyone know what size that nut is? Theres got to be an extra deep socket that would do the trick, just dont know the size, looks to be around 1 1/2". Thanks! -Steven
Thank you received: 779
5 months 2 weeks ago #255866
a long tube spanner no idea what size it is. the outer tube that makes the housing i think is only pressed in and has a gasket underneath look in the parts book to confirm. might be able to remove it and then use a normal spanner
Thank you received: 100
5 months 2 weeks ago #255868
by side-seat
Are you sure it's not the two thin copper rings that seal the cap and base of the outer shell?
Thank you received: 29
5 months 2 weeks ago - 5 months 1 week ago #255869
by bcwayne
I believe the nut is 1 3/8''. Buy a cheap socket, cut it in half and weld a piece of pipe in between the the two halves. There is an o ring or quad ring at the base.
Last edit: 5 months 1 week ago by
bcwayne. Reason: correct information provided
Thank you received: 113
5 months 1 week ago #255874
by PhilC
That part number is the same as the nuts in my D8 filter housing and it takes an 1 3/8" socket.
5 months 1 week ago #255889
by bcwayne
Thank you Phil for correcting me... I was relying on information posted on ACMOC years ago by another member. I went out and removed one of the cannister nuts and it is 1 3/8''.
Thank you received: 794
5 months 1 week ago #255912
by PhilC
I made this one today out of a 35mm 3/4" drive socket. Seems to be a slightly tighter fit than the 1 3/8 but it was all the hardware store (Bunnings) had in stock.
Time to create page: 0.167 seconds
