D2 5U float
D2 5U float
1 month 2 weeks ago #255827
by Kaeson1972
I recently acquired a 1948 D2 5U #1011 it has a Cat 2S blade with a #44 hydro unit #4W-45 up front. The lever gives me up, neutral, a very small spot where it will float, then power down. I am wondering if this float position is just a fluke or a result of something wore in the valve? I have slammed it hard forward as much as I dare and cannot get it to float, is there any way to get it to float in the far forward position like it should? Any help would be appreciated, thank you.
Thank you received: 584
1 month 2 weeks ago #255839
Hi Kaeson, I don't think it has a float although I haven't used my unit for a while and it's a 9W #44. I could be wrong : )
Thank you received: 767
1 month 1 week ago #255890
by Kaeson1972
Do you guys know if they made the 44 with and without float? And is there any way to tell if a units got it without having the machine running… I’ve got another 5U that I have not got running yet but it’s got a 44 on it too so just wondering about that one without having to go through the hassle of switching them out to find out
Thank you received: 737
1 month 1 week ago #255891
Units 4W1 to 4W484 did not have float unless the field installation conversion valve was installed.
1 month 1 week ago #255893
by Kaeson1972
Thank you guys very much for the info … guess I’m out of luck I’ve got 4W-45 and 4W-477. I’m sure there’s no chance in finding the conversion parts either?
1 month 1 week ago #255898
It might be easier to just swap in a later model #44. If you can find one that matches your pipework and controls, then it would be a direct swap
1 month 1 week ago #255903
by Kaeson1972
I believe you are correct Neil, would like to get this one set up like that and swap the hyster winch off my other one onto this one too. Then just have the other one as a drawbar rig.
D2 5U float
Time to create page: 0.161 seconds
