Loosened the tracks successfully
Thank you received: 43
1 month 2 weeks ago #255823
by Captain Beans
So I managed to loosen up the right track by myself with help from someone that is helping me build my corral and fences
I needed a couple wrenches the cordless impact gun heavy duty I bought a couple years ago it required a fully charged battery though because the nuts were stuck by decades old rust
a pipe wrench and a pipe for leverage some common sense voila! Oh and water turns out water loosens up rusted bolts better than penetrating oil
previously I took the center bolt to the machine shop to get it renewed and put it back in position
now I have no steering left or right I will adjust tomorrow
I received the acmoc magazine in my mailbox last week it’s very cool to look at all the machines from around the world!
Thank you received: 911
1 month 2 weeks ago #255825
by Deas Plant.
Hi, Captain Beans.
Good stuff. Thanks for sharing.
Thank you received: 679
1 month 2 weeks ago #255845
by juiceman
That's great news Captain Beans. Improvising is normal here. Back in my early days on the farm, we didn't have those fancy cordless tools; I am very spoiled today with all of my new to me 18 volt Milwaukee toys. The old school mechanics did a lot using only a handful of tools, a BIG hammer being their most used one! Brute muscle and some common sense got a lot accomplished.
Hope to see more pictures of you farming. JM
Thank you received: 294
Thank you received: 23
1 month 2 weeks ago #255851
by blwatson
I did not have an impact wrench but used a torch and got things good and hot and it finally came loose. Glad to see you are making progress. I know it feels good to actually get things like that completed successfully.
D47U #11867-1950
Idaho
Thank you received: 737
1 month 2 weeks ago #255852
I recall one of the issues was a track chain with non correct master pin that had hogged out the link pin holes. As this is a hunting tooth sprocket arrangement that needs to be taken car of or the stretched pitch at the master pin will see every tooth on the sprocket and rapidly wear the sprocket out.
Thank you received: 767
1 month 1 week ago #255864
its surprising how well water can work as a solvent and more the fact of removing dirt frees things to move.
Thank you received: 88
1 month 1 week ago #255884
by kittyman1
my guess is Water is the number ONE solvent, take care of it !
Thank you received: 44
1 month 1 week ago #255887
by Captain Beans
So the machine is steering to the left again and the tracks are not super tight anymore! It’s incredible how well made these machines are!
youtube.com/shorts/jDgZ0CN9wsg?si=kyqR8pmBi23wTYwm
So yeah the spring center bolts are very important and it was very important to retighten and machine the bolt that unfastened by itself l. It wasn’t broken I found out that the bolt is used to compress the spring so that it would fit inside the track then the nut can be backed off, however without the center bolt in place if the spring broke in pieces or something unexpected happens because of the compression force there is a real risk something deadly may happen to you so rhanks for the advice
