Cat D7 Advice
1 month 1 week ago #255947 by biged5033
Replied by biged5033 on topic Cat D7 Advice
@D8Dude
Is the the correct Stromberg carb?
www.ebay.com/itm/285522135053?itmmeta=01...7Ctkp%3ABFBMvojihtlj
1 month 1 week ago #255950 by D8Dude
Replied by D8Dude on topic Cat D7 Advice
Bigred,
That Stromberg looks similar, but the throttle and choke mechanism and linkage all looks reversed and on the wrong side. Maybe that's because you drive from the wrong side of the vehicle over there, I don't know 😂. I'm not 100% sure, but I think that other device on the choke mechanism is for an automatic choke too, which won't be ideal for this application.
1 month 1 week ago #255951 by neil
Replied by neil on topic Cat D7 Advice
I goggled it and someone on a Holden website said the model was BXUV-2 for the earlier smaller engines and BXV-2 for the later larger engines. But, your ebay carb and these models might be similar enough to be used. Take a look at what the first poster on this thread says - www.fastlane.com.au/Forum/postsm25105_all-about-strombergs.aspx
1 month 1 week ago - 1 month 1 week ago #255955 by biged5033
I was able to find a magneto from Mark's Mags in Connecticut. Mark told me from the pictures I sent that it had already been swapped to a Wico mag. I should get the mag in a few days.
Carbs Only in California is sending me a carb kit...assuming it's the right one. Mark's Mags told me to contact Carb Specialist in Georgia and talk to John or Greg to get better info on the carb, carb kit, or possibly the whole carb. I ended up getting Greg on the phone. He sent me pictures of where the model/serial info should be on the carb and I forwarded that to the owner. Hopefully, I have that info soon.
Also, I have Robin at Ray's Used Equipment in Texas attempting to find filters. Do you all know what filters a 9G uses for air, fuel, and oil?
I'm going to have quite a bit of money into this thing before I ever see it
Last edit: 1 month 1 week ago by biged5033.
1 month 1 week ago #255956 by D8Dude
I had a closer look at the Stromberg carbs I've used, the number on the mounting flange is:
2376050
BXUV-2
The number on the top of the carb on a metal strip is:
23 • 3005-4C
Also, a drum of diesel engine oil is all you will need to service the air cleaner after you give it a clean, it should be an oil bath type with washable screens. No new filter required there.
Here's a couple more pictures too.
1 month 1 week ago #255957 by trainzkid88
Replied by trainzkid88 on topic Cat D7 Advice
carb kits where available from the dealers if you have the part numbers for them. i dont know if they still are but they were a few years ago when we need one for our cat.
1 month 1 week ago #255958 by trainzkid88
rare spares will probably have parts for a stromberg carb they were made by bendix corporation. very common on general motors-holden vehicles.
1 month 1 week ago #255960 by biged5033
Y’all are awesome! Thanks very much for the continued help!
1 month 1 week ago #255969 by Ray54
Replied by Ray54 on topic Cat D7 Advice
As for filters the air is a oil bath unit, so the cheapest motor oil you can find. The original oil filter was a brass screen, but many where updated to the by pass type canaster. The fuel was also a brass screen from factory. But they also had a update kit to use the same string wound filter that was standard in Cats until the 1950's.
1 month 1 week ago #255972 by biged5033
Thanks Ray!
