- Thank you received: 1
Don't let the control shaft drop down or you will bugger up the detent mechanism.
There is a Service Bulletin upgrade.....The single seal has been replaced by the use of two seals.
Any tips to prevent the shaft from dropping down? Im thinking reassemble the shaft and controls with the pan off so I can watch it closely.
When I put those numbers into google I get lots of hits, also 1J2381 crosses to 6F3578 and 9F3847 and 1j2382 crosses to 4B1925 an 4B1927( might use both) and 9F3849.
You will need to remove the front cover to replace that seal.
www.google.com/search?q=caterpillar+1j23...ceid=chrome&ie=UTF-8
www.google.com/search?q=caterpillar+1j23...sclient=gws-wiz-serp
www.finditparts.com/products/408452/national-seals-471281
Fantastic, thanks! Can a guy get away with using Black RTV over a pan gasket?
it might sound strange but a smear of grease will allow you to reuse a gasket and it still seals properly a light smear that is.
it also helps hold it in place while you get the bolts in.
I will keep that in mind. To be honest I am just running it how it is right now. This leads me to my next question. What should the fluid level in the surge tank be? When I got it I looked in the tank, saw it was low and then dumped a few gallons in it. Now reading more I am realizing that it shouldn't be full of oil. Has me thinking it is causing it to leak possibly more than it should with all that fluid sitting above it in the tank.
cat@acmoc.org
- Chris R
- Jason N
