Rescuing a "broken" D6 8U
1 year 5 months ago #242583 by LangdonStevenson
Hi, LangdonStevenson..
Try the gentler ways first, pressing hard on the fan belt while trying to turn the fan both ways, trying to gently bar the flywheel over or - if there is a nut on the crankshaft pulley - trying to turn that with a socket and bar. You really ned to rotate it a full revolution to be sure that it is fully free.
Make sure you have the decompressor in the Start position so that you are not battling compression. (I.D.10T. mistake.)
That's definitely the way I was thinking of going.  My tool set isn't big enough for a machine this size so I'm going to have a look at it this weekend and give the fan a pull, see what happens - and yes, decompressor definitely open!  After an initial inspection I'll have a better idea of what I've got and what I need to come back with.
212 grader, 301.5CR excavator, 226B3 skid steer (and fingers crossed a D6 8U coming my way soon!)
1 year 5 months ago #242584 by LangdonStevenson
The D318 also has a nut on the crankshaft but it's bigger.....2-3/8" if I'm remembering correctly.
Good to know thank you!  I'll put an appropriate socket on my shopping list in due course if the nut is accessible.
1 year 5 months ago #242585 by LangdonStevenson
pictures would help
Indeed they will. The machine is about four hours away and the owner doesn't have photos.  I'm going up with them this weekend to inspect and will take plenty of photos when I do.
1 year 5 months ago #242586 by LangdonStevenson
Thank you Phil, I'm looking forward to seeing the machine on the weekend and seeing exactly what its configuration is.  Should let me answer all of these sorts of questions.
1 year 5 months ago #242587 by LangdonStevenson
If a Cat pump and the u joint you can use a short bar in the u joint. Of course may have to remove a belly guard to get bar in and to turn. You can also turn from the clutch end. The later wet clutch is easier with the espoused u joint between clutch and transmission. But with the clutch cover off the dry clutch it can be used to turn the engine as well.
Good to know thank you!  I won't have the tools to pull off a belly pan when I have a look this weekend, but that's handy to know for the future if I can't get to the crankshaft from the front end.
1 year 4 months ago #243657 by LangdonStevenson
Quick update: I'm off to inspect this D6 8U on Sunday this weekend! I'm excited to finally be getting a look at it. Photos and video to follow!
The following user(s) said Thank You: kracked1, Fat Dan
1 year 4 months ago #243680 by bernie
Replied by bernie on topic Rescuing a "broken" D6 8U
Good luck and keen eye!
The following user(s) said Thank You: Fat Dan, LangdonStevenson
1 year 4 months ago #243736 by LangdonStevenson
Ok first inspection is complete.
The machine is a D6 8U according to the owner. It is a cable blade machine. And while it looks pretty rough it seems to be in working order. My observations:
  • All levers and pedels work
  • Engine has oil which looks good
  • Exhaust has a can over it to keep water out!
  • With compression released I can turn the fan by hand. With compression engaged I can't turn the fan.
  • Undercarriage look surprisingly good. No visible wear on the rollers, front idlers, and track chains. Drive sprockets have some wear visible
  • Blade skin is worn and has a hole. Corner bits on blade are worn but serviceable
  • It has a tree spear
Bottom line is I think that it will run with with a little effort unless there is something badly wrong internally, or perhaps the pony motor has an issue.
The hour meter says 1095,but I'm guessing it's been around the clock at least once!
One question: can anyone tell me where to fing the serial number on it? I looked hard but couldn't spot it.
1 year 4 months ago #243737 by kracked1
Replied by kracked1 on topic Rescuing a "broken" D6 8U
Top left corner of the rear casting. In your last picture, to the left of the rectangle cover. If the tag is gone, look for two rivet holes it will be stamped between the rivet holes.
1 year 4 months ago #243758 by LangdonStevenson
Thank you Kracked1. I'll check that out!
Time to create page: 0.463 seconds
