Wanted: D4 Water Pump Housing 4F7708 / 4F7963
Showing 1 to 7 of 7 results
Dirtbiker1824
Send a private message to Dirtbiker1824
Hello,
Unfortunately I cracked the top of my water pump housing, the side that attaches to the block, and I'm hoping someone has one.
Tractor SN: D47U931
Mike
Fri, May 23, 2025 5:22 PM
gemdozer
Thank you received: 12
I have the D4 water
Fri, May 23, 2025 11:52 PM
gemdozer
HI I check this morning about D4 water pump but mine have 2h5847and the front is 4f7747.
HECTOR
Sat, May 24, 2025 4:33 PM
Dirtbiker1824
This is the part I'm looking for, its what the pump attaches to and is attached to the block.
Sun, May 25, 2025 5:54 PM
gemdozer
HI I recheck tomorrow but mine should be the same this pump is in 2 piece ,the rear is bolt to front block and the front have the ampaller with shaft and puly and fan.
Mon, May 26, 2025 1:12 AM
gemdozer
HI I check this morning my d4 water pump and she bolt in front motor on top by 4 bolts and 4 bolt at bottom and in your pump picture the front is missing some parts it look like a marine motor.
HECTOR
Mon, May 26, 2025 6:15 PM
Dirtbiker1824
Yeah the back part is what I need, where the thermostat goes. Let me know how much you want for it. I sent you a PM.
Wed, May 28, 2025 2:05 AM
gemdozer
HI My water pump back parts number is 2h5847 it should fitt and just the regulator is different but you could check with your CATERPILLAR dealer.
HECTOR
Wed, May 28, 2025 10:40 AM
