Wanted cat ten parts
Johnsd2
Send a private message to Johnsd2
I am in need of the correct oil cleaner housing and air cleaner housing.my air cleaner housing botton is gone..
If anyone knows or has one I would sure appreciate it thanks.
Sun, Jul 12, 2020 12:03 AM
brewzer
I am not sure what you mean by the oil cleaner housing.
Sun, Jul 12, 2020 11:16 AM
Johnsd2
Reply to brewzer:
I have this 1929 cat 10, pt14. It has a oil filter housing attached to the dash. I don't think it's right. Not sure were the original oil filter goes..
Sun, Jul 12, 2020 11:35 PM
Lance Jones
Reply to Johnsd2:
Johnsd2, Sounds like You have an aftermarket Oil filter fitted, I have seen a couple done. To my knowledge Cat never fitted them to 10-15's , Your air Filter sounds like You Just need the Oil Cup , Often get rusted Out , can be repaired with Fibreglass or Find another, You may have to Buy a whole Filter . Some Pics will help Us Help You . LJ
Mon, Jul 13, 2020 2:35 AM
Johnsd2
Reply to Lance Jones:
Here are some pics..my air filter bottom pretty bad. Don't know how to get the rest apart to clean..looking for a better one.
Tue, Jul 14, 2020 9:04 AM
Andrew
Reply to Johnsd2:
The air cleaner bottom looks very repairable to me . Dont forget this is a 90 year old machine.
Clean it up thoroughly and line it with some kind of fibreglass repair .
Tue, Jul 14, 2020 11:31 AM
Thank you received: 62
Reply to Andrew:
Other than the wing nut on top of oil filter canister being new to me looks like a Fram brand canister that took a CP1 filter. That was a common add on to early engines that did not have a factory filter. But there could be a lot of other after market brands I have never seen.
I would think the air filter is repairable. But until you clean the rust you never know.
Wed, Jul 15, 2020 12:55 AM
Lance Jones
Reply to Ray54:
As Andrew has said , Bead or sand Blast Rust area and Then Fibre glass the whole Bottom.Clean up nice after Glassing and Paint and You won't know its Not Original .LJ
Wed, Jul 15, 2020 10:32 PM
Johnsd2
I want to say thanks to everyone for the information. I have it at the bead blaster now. I will definitely try the fiberglass. I am going to use the oil filter as well till I can find out what the originally came with.. every peice of my 10 is rusted mess, I will restore it. Thanks again.
Thu, Jul 16, 2020 6:03 AM
