sale- 46A-D8 pump -tank -valves
tanker
Send a private message to tanker
Took all hyd that ran blade off 46A D8-was a winch cat w/o blade since early 80's so all should be in good shape-anyone need? make offer
Tue, Jun 11, 2013 8:50 PM
razz
Send a private message to razz
i might be interested will it fit a 36a does it run off the front. razz.
Wed, Jun 26, 2013 8:11 AM
razz
Reply to razz:
tanker are you home or is water to deep. razz
Fri, Jun 28, 2013 6:34 AM
tanker
Reply to razz:
Been busy chasing ducks off fields😆- valves are in tank that was mtd on RH fender [pic 1] w/ linkage mted on floor on RH side of seat = replaced w/ small tank [pic 2]- pump was mtd on back side of bell housing on RH side = replaced w/ smaller one for ag equip.[attachment=18341]000_0652.jpg[/attachment][attachment=18342]000_0808.jpg[/attachment]
Sat, Jun 29, 2013 10:05 PM
razz
Reply to tanker:
I would like to look at it I have a cable unit on mine will it fit with the cable unit on I need to have the unit to run scraper. I was thinking about getting a tile plow. need hyd.
Sun, Jun 30, 2013 5:09 AM
Mike Walsh
Reply to razz:
Tanker's hydraulics won't interfere with either the front or rear of your tractor. You're thinking of the earlier 46A-s with front pumps. I'm not sure if Tanker's hydraulic pump will mount to your bell housing. You'll have to post up your serial number. Perhaps OM or someone else will have the parts info for your bell housing. If the hydraulic pump can be powered off your bell housing and Tanker has all the plumbing, you can mount the tank to your fender and plumb some remotes to the rear for your plow without too much trouble. Next you'll need to collect a hard nose, cross tube and blade so you will have something to do after you convert your cable can to hydraulic.
Sun, Jun 30, 2013 7:21 AM
razz
Reply to Mike Walsh:
serial # 36a 3715 Razz.
Sun, Jun 30, 2013 7:00 PM
Reply to razz:
Early 36/46A's up to s/n 36A4469 & 46A10725 normally ran 100 gpm front mounted pumps.
Still had the power take off gear drive and could mount the 29 gpm single pump to run hydraulic blade tilt on cable units.
Later units run two section (piggy back) pumps mounted to the power take off gear drive, one section for tilt and the other for blade and ripper @ 70 gpm. Still retains the PTO winch shaft drive.
Gets pretty messy with up to three valve operation and combinations of blade, ripper and tilt combinations. All with fender mount tanks.
So I guess the answer is you could still adapt the later PTO drive pumps to earlier units.
Mon, Jul 1, 2013 9:56 AM
razz
tanker maybe i will come next week and look . let me know your loc or phone number. Razz.
Wed, Jul 3, 2013 6:26 PM
