Parting out D2
Parting out D2
Showing 11 to 14 of 14 results
2
samueljollygarmins
Send a private message to samueljollygarmins
This is still available..
Mon, Sep 15, 2025 12:33 PM
Thank you received: 29
Hi Samuel, where is the machine located? I also have a D2 with a Teale TL20 so I'm kind of curious about this one. I'm planning a trip from NY to IL to pick it up so if you're along the way, I'd like to come take a look. Could you let us know the serial number - likely starts with 5U and then five digits. Serial # tag can be found on the driver's side / left side from operator's perspective at rear of main engine block, and also on the rear transmission case on the left top, above the rear hitch. Both are obscured on your tractor because the loader frame is blocking a view of the rear left side of the main engine, and that cross bracket is blocking a view of the rear top of the transmission case so you'd need to kind of get in there with a rag to clean it and take a photo of the tag.
What's the reason for the track chains being disconnected?
Thu, Sep 18, 2025 1:05 AM
clayton
Thank you received: 5
Hi where is the D2 located at?
Thu, Sep 18, 2025 10:01 AM
samueljollygarmins
missouri
Sat, Sep 20, 2025 5:20 AM
2
