Mt42 starter drive end housing wanted
Willy
Send a private message to Willy
I’m looking for a lead on where I can purchase a drive end housing nose cone for a mt42 starter. I’m trying to do the electric conversion for my d6-9u! I have the starter and helical drive already but missing the nose cone.
Sun, Apr 26, 2026 6:52 PM
Thank you received: 45
Depends on what lever housing the starter has and the indexing your trying to get. Either the 6-bolt indexing version Delco #1988748 or the 12 bolt indexing Delco #1988854.
Mon, Apr 27, 2026 1:14 AM
Thank you received: 60
Hi OM, is your conversion page still available? I clicked on a link I had for it with no luck bring the page up - https://sites.google.com/site/oldmagcat/ I have a DE start 5U and would like to assemble parts for when the OEM starter eventually gives out
Tue, Apr 28, 2026 12:55 PM
EZCAT
Thank you received: 21
The Regular Starter nose would work , just take it of and stick into the starter hole on the cat and note where you need to grind the nose unto you can rotate it to line up bolt holes and still have clearance for the flywheel teeth to clear , we have done that many a times and it works
EZ
Tue, Apr 28, 2026 1:04 PM
That site is lost in the "cloud" somewhere and I'm not going to chase it.
D2 conversion (new installation/not replacement of original) is a no brainer. Us a 42MT with either a Delco 1988891 (371-12179) 6-indexing hole and 1/2" mounting hole drive end housing or a Delco 10476100 (371-12128) 12-indexing holes with 5/8" mounting holes (comes with bushings for 1/2")
and the 11 or 12 tooth helical drive gear.
Tue, Apr 28, 2026 4:18 PM
Tue, Apr 28, 2026 4:19 PM
