Generator gear
Generator gear
Showing 1 to 9 of 9 results
John-2210
Send a private message to John-2210
Looking for a L-636 21 tooth generator gear for my No. 10 Auto Patrol. Same engine as a Twenty Eight tractor.
Thanks John
303-548-four three six seven
John
Fri, Apr 24, 2026 4:25 PM
naylorbros
Online
Thank you received: 34
I would love to find 2 of them
Sat, Apr 25, 2026 6:19 PM
John-2210
  • I have a 26tooth gear that came on the generator. The pitch is the same as the L-636 but the angle is different and obviously larger diameter than the 21tooth L-636. I’d part with it, but I can’t identify it.
John
Sun, Apr 26, 2026 12:49 AM
naylorbros
Online
I can not remember the part number right now but if I remember it will fit the D4400 and D4600 engines. I am working on a list of generator gear part numbers and what they fit. It will be a while before I get it done as I have to produce a paper every other week for my masters classes right now
Sun, Apr 26, 2026 4:34 AM
John-2210
I looked up a D4400 on sis and unfortunately no match. (it’s the black and white photo below)
I also added pictures of the generator itself and its Delco number.
I appreciate any help you have the time for… maybe if you know how to cross the Delco number to a cat number that would help? Also if you have an actual photo of a L-636 gear that might help me. I’m considering having one custom made at this point.
John
Sun, Apr 26, 2026 2:59 PM
John-2210
I can’t seem to get the photos to load. Delco number is 953R
John
Sun, Apr 26, 2026 3:05 PM
Delco 953R = Cat 1B5785
1B5785 uses a 3B2770 (26T) gear (info from 4G D4 parts book (D4400)
Sun, Apr 26, 2026 3:27 PM
naylorbros
Online
I posted a couple of picture on your other post. I think I have a L636 on my Twenty Eight. I have not taken the generator off to see if it is still there. I thought I had one on my Twenty Five but I pulled the hydraulic pump that was mounted where the generator goes and there was no gear. I call pull the generator on the Twenty Eight, but it might be a couple of weeks before I can get to it. The best thing is to keep reminding me about it as otherwise I will forget to do it.
Sun, Apr 26, 2026 3:57 PM
John-2210
I don’t need to create more work for you. I’m mostly just concerned that A: the generator I have, 953R is correct-ish and B: If I have a 7pitch 21 tooth gear with a 60* angle made will it fit. It’s not cheap!
John
Sun, Apr 26, 2026 5:16 PM
naylorbros
Online
I do not mind doing it as I need to see what is there so I know what I need to find.
Mon, Apr 27, 2026 3:36 AM
