D6 9u parts
Linkbeltcrane
Send a private message to Linkbeltcrane
Am i correct in believing ,that Cat made two different generator configurations on the D6 9u tractors, a high and low speed? Perhaps 6 and 24 volts? And the housing that bolts to the 318 engine are different for the different generators???? Any HELP. Thank you
Wed, Jan 30, 2019 1:46 AM
Thank you received: 62
The Cat parts book has a lot of different generators. Most are 6V, I am not sure there is a 12V but yes a 24V for the direct electric start.
The reason for more than one mount is if it uses a idler gear to reverse the direction. I am not sure if that configuration is out there for the 318 engine but probably.
In the old days it was common to gut a 6V generator and have a bit of shaft exposed to add a pulley at the rear and power a alternator. The pony starter seems to handle 12V O'k, and 12v lights are so much more common.
Today there are mounts you can buy that direct drive alternators. My experience is the drive gear is hard to find and expensive when you do.
Wed, Jan 30, 2019 11:48 PM
Thank you received: 95
Reply to Ray54:
have not looked into the reason for different Generator drive ratios, but, logic tells me that there would be a need to have a generator run at an optimum speed for charging outputs.
I can see the need on stationary engines that are running at reduced RPM's to up the generator speed to maintain a required output.
I stand to be corrected.
Thu, Jan 31, 2019 9:11 AM
Linkbeltcrane
Reply to Ray54:
[quote="Ray54"]The Cat parts book has a lot of different generators. Most are 6V, I am not sure there is a 12V but yes a 24V for the direct electric start.
Today there are mounts you can buy that direct drive alternators. My experience is the drive gear is hard to find and expensive when you do.[/quote]
They made two configurations ,a high speed and low speed. I intend to use to turn an alternator, which isn't restricted to turn a certain direction, must need old generator with gear to fit my configuration whish has an idler gear in housing that bolts to main engine Cat 318
Thu, Jan 31, 2019 10:13 AM
gemdozer
Thank you received: 25
Reply to Linkbeltcrane:
I have the generator with the 19 theets for d6
Thu, Jan 31, 2019 6:23 PM
Linkbeltcrane
Reply to gemdozer:
How much would you have to have for it? Shipping cost? The d6 it came from is a 9u with the idler gear in housing?
Thu, Jan 31, 2019 7:31 PM
