D6 9u parts
Showing 1 to 6 of 6 results
Linkbeltcrane
Send a private message to Linkbeltcrane
In need of generator any condition with gear and gear case that bolts to engine. Gear case not needed if generator is off same type gear case as mine (has idler gear )Also need complete pony motor clutch with housing bendix ,the complete unit.for 9u d6. Please contact via e mail. [email protected]
Tue, Jan 22, 2019 1:43 AM
gemdozer
Thank you received: 25
I have a complet D6 poney cluch housing assembly with pinion and should have a generator
Wed, Jan 23, 2019 5:15 AM
gemdozer
Reply to gemdozer:
I recheck and have cluch housing complet but the sleeve on should be for d4 and have a generator 6volts 40 ampere
GRB640 B203 ---AMERICAN BOSCH with no gear on and have smaller one 1102425 DELCO with no gear on
Thu, Jan 24, 2019 3:12 AM
Linkbeltcrane
Reply to gemdozer:
How much will you take for clutch housing complete? The gear for generator is what i need most. Thanks Bill
Thu, Jan 24, 2019 6:57 AM
Linkbeltcrane
Reply to gemdozer:
What is the sleeve you mentioned ??
Thu, Jan 24, 2019 6:59 AM
gemdozer
Reply to Linkbeltcrane:
The sleeve is the last piece on from the cluch housing with the 2 latchs and she pusch the pinion on flywell
Thu, Jan 24, 2019 6:00 PM
Linkbeltcrane
Reply to gemdozer:
How much for the complete pony clutch ,i have d6 sleeve. Is the sleeve the only difference between clutch unit for d4 and d6? Thank you
Thu, Jan 24, 2019 10:06 PM
