D4400 engine parts wanted
Showing 1 to 10 of 13 results
ChrisRoyd2
Send a private message to ChrisRoyd2
I am looking for several parts for a D4400 in a 112 grader. Ser# 2M1123. In search of
30 under rod and main bearings
camshaft
cam gear
idler gear
2 pistons
1 rocker shaft assembly
I am sure there will be more.
Sat, Jan 2, 2021 3:46 AM
ChrisRoyd2
More pictures.
Sat, Jan 2, 2021 3:51 AM
gemdozer
Reply to ChrisRoyd2:
More pictures.
Do you have some parts number
Sun, Jan 3, 2021 2:32 AM
ChrisRoyd2
Reply to gemdozer:
.030 undersize bearing group 6B3333
Piston 1H1696
Cam gear 5B3099
Idler gear 5B3071
Camshaft 3B8889
Rings 9H1214
The part number for the gears are the ones cast into the gear.
Mon, Jan 4, 2021 2:17 AM
Piston 1H1696
Cam gear 5B3099
Idler gear 5B3071
Camshaft 3B8889
Rings 9H1214
Check with Florin Tractor they show having most. Machinery Trader parts search shows some other places also.
Mon, Jan 4, 2021 3:08 AM
ChrisRoyd2
Thank you. I didn't know that resource existed. I am still having trouble trying to locate the piston. I would be interested in used if anyone has some. Also would anyone has a part number for .030 under rod bearings I would appreciate it. Thanks again.
Mon, Jan 4, 2021 10:41 AM
rax200
Hi ChrisRoyd2,
Can you please tell us the type of bearing used on the crankshaft and big ends, do they use shims or not?
Regards
Daryl
Mon, Jan 4, 2021 5:53 PM
ChrisRoyd2
Reply to rax200:
Hi ChrisRoyd2,
Regards
Daryl
They are the later ones with no shims. It looks like mains are available. Just the rods now.
Mon, Jan 4, 2021 8:16 PM
gemdozer
I have the cam gear 5b3099 and idler gear 5b3091 in very good condition
Wed, Jan 6, 2021 2:55 AM
ChrisRoyd2
Reply to gemdozer:
I will keep that in mind. I am wondering with all the tust damage in it could one get a motor that runs out of a d4 and change the necessary parts to make it fit?
Wed, Jan 6, 2021 9:24 AM
ChrisRoyd2
Supposed to read " rust damage"
Wed, Jan 6, 2021 9:25 AM
