Hi I have a D4 from the 1950s the serial number is scratched so I can’t give a definite year but it has the TU4C zenith carburtta and the eisman magneto.
It’s been siting for a while and I’m trying to restore it but I’m having issues with starting the pony motor.i managed to get a replacement magneto so it has good spark and I can feel good compression but I suspect the carboretta is blocked or not letting fuel in
Is it normal for these engines to be hard to get started by hand?
And I’ve heard zenith have gone out of business and it’s hard to find the correct rebuild kit for the carboretta (K2067)would anyone know where I could get one.
I’m from the midlands in England I’m quite new to the engineering industry as I’m 17 so any help would be greatly appreciated
So if anyone has any tips or suggestions about getting the d4 started and some common faults please share
Thank you
Louis
Hi Louis, yes it is typical for the starting engines to be hard to start (in my opinion) but this is usually due to a lack of regular preventative maintenance and/or regular running. If they're run regularly (e.g. if they were in production working 5 days a week), then they're usually pretty easy to start because they have to be. So, the usual suspects are involved in hard starting:
poor spark - sounds like you have that one dealt with with a replacement mag but you can also refurbish your old one usually just with filing the points (get a magneto file), setting the points gap, and replacing the condensor. Coupled with that is checking that the plug wires are good (only use solid core wires, not carbon filament or such) and the plugs (non-resistor) are good. Be aware that a spark that looks "ok" out in the open air can then fail to spark under compression. You can test if your spark is any good under compression independently of the fuel buy tipping a small soda bottle cap of fuel down the carb throat to see if it fires (or a small sniff of ether). You just need to know that it fires - you don't need to run it until you have the carb dealt with (next)
poor mixture - this one's a little more involved but is still pretty easy. Start with cleaning the pony tank and fuel bowl and filling with fresh, non-ethanol gas. Then remove the carb to install the kit which you can buy online (ebay, mcdonald carb, and others). Oftentimes, the carb passages are blocked and the usual suspect is a gallery along the bottom of the fuel bowl. You'll see a lead plug which you can carefully drill out (finish it off by hand) and then use a 1/8 bit (I think) to hand-clean out the passage. You can also remove the plug on the other end of that gallery that travels upwards through the compensator jet. Clean all that out. Carefully unscrew the main jet in the bore of the throttle body (long thin brass tube that spans the bore). Careful with that as it's quite easy to damage then check that it's clear. The "bullseye" gasket between the fuel bowl and the throttle body can sometimes be damaged by backfiring with the inner of the two rings not sealing properly. You can carefully face both surfaces before reassembly to confirm that the faces are flat and even on both rings. If you find that it will run fine at part- and full-throttle but not low idle, then there is a brass plug in the bore adjacent to the closed throttle plate. Holding the throttle plate open, punch that plug into the bore to remove it then clean up the gallery that feeds it. That plug is the low idle "jet" and has a little notch in one side of it. Reinstall it from the outside in (same direction you removed it in) with that notch down so it sees vacuum at closed throttle. You should then have a good low idle. Reassemble the carb using a .177 cal BB pellet mushed into that lead plug you drilled out to reseal the gallery. Some dab a little epoxy on top of the pellet but I haven't ever needed to do that. Check the float level is good. The main jet (in the fuel bowl) setting is one turn from memory. There are two types: the vertical adjuster with a regular right-hand thread you carefully bottom out then screw out one turn; the horizontal adjuster is the reverse and in my opinion a bit harder to adjust. Screwing out seats it in the jet so you screw in to open the jet. You need to check that the little right-angle piece under the cover is actually a right angle because over-zealous tightening can bend it making it harder to get a good jet setting. If you have this type, take it apart and you'll see what I'm writing about.
Report back on how you got on, ideally with a video link of it idling nicely : )
Thank you Neil
Realy appreciate this I’m going to try and get that carb rebuild kit and I didn’t know about that passage that needs cleaning out behind that lead plug so I will get that done.and try and get it started once carb is rebuilt
Thank you
You state you replaced the magneto -- be certain the timing is correct. Often when one is convinced the problem lies with ignition, it is carburetion or the other way around. Do the simple fixes first. Those Horizontal Opposed Starting Engines can be very frustrating, even when the carburetion and ignition are correct. Once you have it running, always run the gasoline out of the carburetor. (Shut the fuel off at the tank and let the engine run out of gas). This often makes it easier the next time you try to start and reduces the chances of contamination to the oil sump. Sometimes it is advantageous to open the brass petcocks at the bottom of each cylinder and pull the engine over a couple of times before trying to start it. (IF you get frustrated and it won't fire off - walk away, come back later.) -cts
