D2, D4, D7, D8,…Parts
Showing 1 to 10 of 14 results
Nanda
Send a private message to Nanda
Hello Everyone,
I have recently acquired a lot of parts mostly for D2,D4, etc. Please see the pictures.
There may be some JD and International parts mixed up in the pictures. I will keep some of the D4 parts and some cool to keep items for myself. All the rest is on sale
Please let me know what you are looking for. Text is the best way to reach me out. I have a day job, so please bear with me for any slow responses
Located in Alberta, Canada. Take bulk and save the shipping!!
Nanda
780-903-9814 [attachment=77797]IMG_0156.jpeg[/attachment] [attachment=77795]IMG_0171.jpeg[/attachment] [attachment=77806]IMG_0166.jpeg[/attachment] [attachment=77794]IMG_0168.jpeg[/attachment] [attachment=77798]IMG_0163.jpeg[/attachment] [attachment=77796]IMG_0161.jpeg[/attachment] [attachment=77808]IMG_0159.jpeg[/attachment] [attachment=77799]IMG_0157.jpeg[/attachment] [attachment=77805]IMG_0153.jpeg[/attachment] [attachment=77800]IMG_0155.jpeg[/attachment] [attachment=77803]IMG_0152.jpeg[/attachment] [attachment=77802]IMG_0150.jpeg[/attachment] [attachment=77801]IMG_0146.jpeg[/attachment] [attachment=77804]IMG_0144.jpeg[/attachment] [attachment=77809]IMG_0148.jpeg[/attachment] [attachment=77807]IMG_0151.jpeg[/attachment] [attachment=77809]IMG_0148.jpeg[/attachment] [attachment=77794]IMG_0168.jpeg[/attachment][attachment=77795]IMG_0171.jpeg[/attachment][attachment=77796]IMG_0161.jpeg[/attachment][attachment=77797]IMG_0156.jpeg[/attachment][attachment=77798]IMG_0163.jpeg[/attachment][attachment=77799]IMG_0157.jpeg[/attachment][attachment=77800]IMG_0155.jpeg[/attachment][attachment=77801]IMG_0146.jpeg[/attachment][attachment=77802]IMG_0150.jpeg[/attachment][attachment=77803]IMG_0152.jpeg[/attachment][attachment=77804]IMG_0144.jpeg[/attachment][attachment=77805]IMG_0153.jpeg[/attachment][attachment=77806]IMG_0166.jpeg[/attachment][attachment=77807]IMG_0151.jpeg[/attachment][attachment=77808]IMG_0159.jpeg[/attachment][attachment=77809]IMG_0148.jpeg[/attachment]
Thu, Oct 10, 2024 8:39 PM
Spitzair
Send a private message to Spitzair
I'd love to come peruse your pile of parts for anything D2... where abouts are you? I'm in Slave Lake...
Wed, Oct 16, 2024 10:43 PM
Nanda
Reply to Spitzair:
I live in Edmonton and have some parts located there. Most of it is still at Wetaskiwin and I wont be able to haul everything until next spring next year to give you a full picture. If you are interested in any specific item, let me know.
Lots of pony engine parts like head(may be around 30 heads with different part numbers), block(many of them brazed at the typical low belly area), manifold, crank/cam shafts, valve assembly, governors, diesel fuel lines, rocker arm assembly(not sure if its for D2), valve covers, Diesel fuel injection pump housing with cams, lifters, etc, fuel injection pumps, crank/cam shafts for diesel engine, clutch assembly, lots of gears in transmission, final drives and pto drives, brake bands with pads, lots of filters in original boxes(not sure if it is still usable), etc. to list some of the items I have identified so far
Thu, Oct 17, 2024 3:15 AM
JimA
Send a private message to JimA
Reply to Nanda:
Looking for a starter and starter motor housing for a D82u D7=3T and D8 13A use the same housing
Wed, Oct 30, 2024 4:29 AM
JimA
Reply to JimA:
I am looking for 9 fuill filters for a D82u and a starter and starter housing
Thu, Nov 7, 2024 2:45 AM
JimA
Reply to JimA:
Tue, Nov 19, 2024 1:55 AM
3J
Send a private message to 3J
Reply to JimA:
I am in need of 2 D2 3J,5J main clutch fiber disks. Part number 5B2519 Thank you
Wed, Nov 20, 2024 1:42 AM
Busso20
Thank you received: 26
Reply to 3J:
3J I think general part may have the plate your after, I got one there a couple of years ago
Wed, Nov 20, 2024 5:05 AM
3J
Reply to Busso20:
Thank you Busso but the one that is for sale now fits the NEW plate system and is much thicker and will not work in the old pressure plate and requires the owner to replace the entire unit which is very expensive.
Wed, Nov 20, 2024 5:17 AM
Busso20
Reply to 3J:
Yes that is catch
Thu, Nov 21, 2024 5:08 PM
Nanda
Reply to JimA:
Sorry for the late response for all queries. I may have starter for D8, but no housing. Also available a set of two wear plates on each side of a disc, not sure of which machine it fits, could be a D8?(see snaps from a D8 machine attached).Will post pictures of both [attachment=78403]Clutch Plates.PNG[/attachment] soon
No D8 fuel filters, I might have a D2 clutch disc, but cant get it verified till next spring.
Mon, Dec 2, 2024 10:10 PM
