Crawler Auction in Western NY Area
Showing 1 to 7 of 7 results
ScreaminDetroit
Send a private message to ScreaminDetroit
This is up near my neck of the woods. Thought this might interest some of you. A Best 30 and other early crawlers- Caterpillar, Cletrac, Oliver, etc.
https://bids.aumannauctions.com/auctions/48697-the-de-meyer-vintage-tractor-collection
Thu, Oct 29, 2026 3:13 AM
GrantJ
Thank you received: 13
Kenny will take a semi and get a whole load of Tens. Even a High Ten.
Thu, Oct 29, 2026 4:10 PM
Thank you received: 287
LOL. Not if I can help it, but he has the engine idling and a few sammiches in his overnight lunch bucket ready for HOARDING Tens.
Fri, Oct 30, 2026 3:09 PM
8C 361
Thank you received: 12
A lot of Tens, 2 Tons, and gas Cats kind of going begging at this point. As I learned, a lot of furious bidding goes on after the soft close. Get the semi's ready but don't leave yet.
Tue, Nov 3, 2026 2:22 PM
Thank you received: 78
Going to take a look tomorrow. Might take teh check book....
Fri, Nov 6, 2026 4:48 PM
Had a look at the selection. A couple of pieces in not bad order while most of them had seen a lot of weather and were rusting out. A high Ten that looked in reasonable order will make someone a nice collection piece. I have my eye on a belt pulley assembly that measurements say will fit the Twenty Two
Sat, Nov 7, 2026 5:19 PM
I secured the pulley. Pickup day is Saturday and I'll be looking out for lowboys with CA tags on them ; ) The high Ten went surprisingly cheap so maybe there are a lot more of them than I thought there was. The highest bid was for a high Cletrac F of 7k. The high Ten when for 4700 and a Best Thirty for 5k. Someone picked up a dinky little JD two cylinder power unit on wheels for 120 dollars. Possibly the most interesting piece was a Thirty wheeled conversion. I don't know if it was ever run but it had an unmounted hydraulic cylinder to steer the front wheels, presumably somehow coupled with the steering levers. It doesn't have a steering wheel so it wasn't clear to me how it was going to work
Wed, Nov 11, 2026 1:34 PM
Deebo
Librarian
Thank you received: 107
Nice score Neil!
Fri, Nov 13, 2026 4:09 PM
