Caterpillar HT4 loader (new)
Bob Mocha
Send a private message to Bob Mocha
Caterpillar HT4 hydrulic track loader this machine has been rebuilt from top to bottom. There was nothing overlooked in this rebuild including engine out of frame,new liner kits, rods bearings, main bearings, valves ground, went through diesel pump, rebuilt clutch. Start engine same thing new bearings, rings, valves ground, starter rebuilt, carb rebuilt, start clutch and pinion rebuilt. Hydrulic pump and vavle body gone through every hose was replaced and all four hydrulic cylinders repacked. The transmission was taken completely down with new bearings. The ring gear and pinion removed and replaced bearings as needed same with the final drives. New rails, sprockets,new seat and armrests sandblasted and painted. The restoration took us 2 winters with 3 and 4 guys labor. All this done and has been run less than ten hours. I have all the receipts for every part purchased which add up to $24,000 for just the parts will scrafice for $15,000 cash. Call Bob 402 -659 -8187
Search cat caterpillar loader cat dozer cat d4 antique caterpillar acmoc hydraulic cat loader
Fri, Nov 30, 2018 9:00 PM
STEPHEN
What a beauty! Good luck.
Sat, Dec 1, 2018 1:27 AM
