Cat ten parts wanted
CatMitch
Send a private message to CatMitch
Im trying to bring back to life a 1930 cat ten orchard im needing a few items.
1. At least 1 exhaust valve, would take a couple.
2. 2. The outer housing that holds the points for the eiseman mag or a complete mag (ours is cracked)
3. A rebuildable or ready to use ensign carb ours is broke in half.
4. A lower coolant tube
5. Need both front track idlers and shafts.
6. Need an original tail seat.
7. Need a hand crank.
8. Need the side hood panels and rear fenders.
9. Need the control lever bracket for hand levers.
10. Need a usable manifold (ours is busted).
11. Need a oil psi gauge.
12. Need the manifold heat control lever and shaft.
Im sure im forgeting a few items, pm me if you have  what we need. Thanks
Thu, Jan 20, 2022 2:23 AM
Steve A
Looks like a nice well worth restoring 10,
For valves I used New Eaton valves we matched up for size and cut down the stem to work with the original Cat keepers.
The ensign carbs come up for sale from time to time, here and on e bay
The lower coolant tube is very common to rot out, make a new one, 2 flanges and a tube with a 90 radius.
Many people make oversized from front idler shafts to make up for worn front idler bearings.
Scott Flint makes the louvered side hood panels
Steve Weaver, aka sideseal might still make fenders
Rosewood machine makes manifolds for the 10
This list should keep you busy for a few days.
Thu, Jan 20, 2022 4:51 AM
brewzer
Reply to Steve A:
I have many of the parts you need. Valves, mag, carb Idlers crank Exhaust and intake manifold, oil gauge and heat control lever. I can also advise you on some of the other parts.
Wally - PM me or my email is in my profile.
Thu, Jan 20, 2022 12:45 PM
