Cat 22 1J2XXX parts wanted
Showing 1 to 9 of 9 results
cletracker
Send a private message to cletracker
Hi
Need the following parts for my Cat 22 1J2XXX:
1, Complete Power take out including back cover(or is there a closed cover without the Power take out axel?)
2, Two cylinders, both mine has cracks from bad antifreeze
3, Fire wall, mine has some bad stress fractures
4, Radiator cap
5, Fuel tank caps
Don´t know but parts from other cats may fit the 22.
/Erik
Tue, Aug 18, 2015 8:18 PM
Steve A
I have 2 sets of 2 cylinders for a 22 with piston and compression rings, Oil rings gone, they are in good shape as I believe the engine had top end work done a short time before I scraped the tractor. The freight would be expensive.
Not sure if it was from a 1J or not, can get casting numbers and pics if needed
Wed, Aug 19, 2015 4:55 AM
brewzer
Reply to Steve A:
I have he cylinders, firewall and fuel caps. My E-mail is in my profile. - Wally
Wed, Aug 19, 2015 7:01 AM
sr4440
Send a private message to sr4440
Reply to brewzer:
I've got a PTO.
Scott
Wed, Aug 19, 2015 5:55 PM
cletracker
Reply to sr4440:
I've got a PTO.
Scott
Well, that was a great respons. Will contact you soon.
Regards
Erik
Thu, Aug 20, 2015 12:01 AM
cletracker
Reply to cletracker:
Regards
Erik
I have sent you all PM or e-mail. Photos of my Caterpillar 22 here: http://images.mydozers.com/#!album-41-2
/Erik
Thu, Aug 20, 2015 4:12 AM
cletracker
Hi Pete
Thanks for your comments, they are of great value for me.
First of all, I took the photos when I first looked at the tractor. It was driven into the shed 10-15 years ago and I actually bought the tractor yesterday(after posting my add).
1, Yes, I have the proper fuel tank caps but someone beat them up and broke the flanges.
2, Didn´t know about the precleaner, interesting.
3, Yes, it´s the original oil preassure gauge. Very nice looking. Sadly the water temp gauge is missing.
4, Good to know Cat has the shifter ball and steering clutch handle, anyone know what the partnumbers are?
5, Yes, i mean the piece that fits under the fuel tank support. It is broken in two or more pieces, looks like all pieces are there so one might try to weld it.
6, There are freeze cracks on the outside of both of the double cylinders. Someone has attempted to fix them and painted the areas red, you can see it on one of the Pictures. Just under the manifold. It might be a good repair, don´t know yet.
Have not yet collected the Cat so I might need more parts in the future.
Regards
Erik
Thu, Aug 20, 2015 1:35 PM
Thank you received: 78
Hi Pete
Regards
Erik
Hi Erik,
you could try some Bars Leaks or similar product for the freeze cracks which would be a much simpler "fix" or at least give you more time to find a replacement set of cylinders. Is it both pairs of cylinders or just the front pair? I've been treating my D2 pony motor which has freeze cracks and it's just about dried up. I brazed the cracks to narrow the gap, and then put in the crack sealer a few times and it's turned out quite well. Could you send a close-up photo of the extra gauge - I haven't seen one like that on a Twenty-Two.
Thu, Aug 20, 2015 2:55 PM
cletracker
Hi Erik,
Hi Neil
I didn´t notice that there were an auxiliary gauge on the tractor. Can´t say if it´s original or not. Have to investigate it when I get the tractor home.
/Erik
Fri, Aug 21, 2015 3:00 PM
sr4440
Hi Neil
/Erik
Hi Erik,
Finally got some pictures of the PTO for you
Sun, Aug 30, 2015 10:33 PM
