2HD6 RD6 undercarriage
Showing 1 to 10 of 16 results
u-joint
Send a private message to u-joint
 I believe he said he wants 1500 for the undercarriage. This is in really good shape. I hate to see it go to scrap if anyone here can use it. Eastern Oregon.
Sun, Apr 30, 2023 12:25 PM
Thank you received: 62
The same links as a R series or U series D6 as well just some more links needed. Would fit right on a R5 as well.
Mon, May 1, 2023 4:28 AM
Thank you received: 78
Reply to Ray54:
That's a great price
Mon, May 1, 2023 7:13 AM
u-joint
Here are a few pictures of the entire machine. If I remember correctly the covers are gone above the steering clutches and it's obviously missing the seat. I did not bother to try to turn it over as the exhaust is not covered. The starting engine is stuck.
Mon, May 1, 2023 11:33 AM
u-joint
Here are more pictures. To my surprise the main engine turned over. It must have had a pipe and air intake pipe before they brought it to his lot. I put the transmission in gear and engaged the clutch and could not turn it over very far so the crank is not broke. I hear that's a weakness around here as the farmers would turn them up to 1000 RPM's to get more power but you could break a crank. I have seen one before.
I put my foot against the starting engine crank and it finally turned over. I would guess it was trying to stick. It turns over good now. I rummaged around and covered the exhaust and air intake. Has the large face oil pressure gauge. Wico magneto.
Wed, May 3, 2023 10:56 AM
u-joint
Reply to u-joint:
Here are a few more.
Wed, May 3, 2023 11:02 AM
u-joint
Reply to u-joint:
A few more.
Wed, May 3, 2023 11:05 AM
ChrisRoyd2
Send a private message to ChrisRoyd2
Reply to u-joint:
A few more.
Where in eastern Oregon?
Wed, May 3, 2023 9:41 PM
u-joint
Reply to ChrisRoyd2:
Milton Freewater
Thu, May 4, 2023 11:53 AM
Colton Young
Send a private message to Colton Young
Reply to u-joint:
Milton Freewater
Do you still have the rd6 undercarriage?
Sat, Oct 28, 2023 9:20 AM
Offrd3717
Send a private message to Offrd3717
Thank you received: 5
Reply to Colton Young:
I sent you a private message
Fri, Nov 3, 2023 3:38 PM
