Working on the 60
Working on the 60
Showing 1 to 10 of 10 results
Skinner
Thank you received: 38
Parked the Best 60 in back of the shop 6 years ago. Next time I tried to bar it over engine was stuck with no movement. been thinking about pulling the heads off. Finally yesterday my helpers are now big enough to work on the 60! Found number 1 Piston stuck have it soaking. Might need to pull off the jug and press it free.
Sat, Sep 5, 2026 9:13 PM
Skinner
Sat, Sep 5, 2026 9:14 PM
Skinner
Sat, Sep 5, 2026 9:15 PM
Skinner
AnthonyF
How do you think it got stuck after running, leaky head gasket?
Sat, Sep 5, 2026 10:46 PM
Skinner
No leaks. This engine always had a hard spot in it to bar over. Now I know where the problem is. getting the heads done too.
Sun, Sep 6, 2026 12:08 AM
ianauz
Send a private message to ianauz
Thank you received: 5
Couple of handy looking assistants you have there Skinner . Good to see they share the Passion .
Sun, Sep 6, 2026 3:19 PM
Skinner
These pistons & rods are quite large
Thu, Sep 10, 2026 8:12 PM
Skinner
Thu, Sep 10, 2026 8:14 PM
Thank you received: 227
Skinner - Thank You for keeping the pictures coming, I was a little late for working Sixty's but Dad resurrected two of them from the graveyard, they were a long way from show perfect but they ran. I have fond memories of his Sixty, it was very hard for me to let it go. Glad to see you have a new generation willing to work on it and have it running again. - cts
Fri, Sep 11, 2026 1:52 AM
Skinner
Update. After soaking with ATF & acetone was able to free the piston with a block of wood and sledgehammer found a rusty spot. Where rings were sticking. some rings rusted to the piston also. Was able to clean the rings replaced a few. Honed the cylinder. Put the piston back in the cylinder and connected to crankshaft. Don’t have the heads on but now the crankshaft and pistons turns over easily with the fan blade. Should make for an easy starting tractor which it never was before. Skinner
Tue, Sep 15, 2026 8:06 PM
