What Grease is best?
Showing 1 to 7 of 7 results
lyoncat
Send a private message to lyoncat
I’m trying to find what the medium weight (cup grease) that was used for the water pump shaft/bushing and packing glands on the 2tons and others!
What is available in today’s equivalent grease that is suitable to use for that application?
Mike.
Sun, Jun 17, 2012 7:59 AM
Jon
Send a private message to Jon
I have a one pound can of this fine GOO from the local farm irrigation supply. $35
M A T E R I A L S A F E T Y D A T A S H E E T
06-011 GARLOCK NO.2 LUBRICATING COMPOUND CM#700447
GARLOCK INC
300 ALLING DRIVE
SODUS, NY 14551
(315) 483-6961
*********************** NO HMIS RATINGS *************************
*********************** NO NFPA RATINGS *************************
SECTION I PRODUCT IDENTITY
SECTION II HAZARDOUS INGREDIENTS & EXPOSURE LIMITS
CHEMICAL NAME CAS # %
GRAPHITE, NATURAL 7782-42-5 50.00
SECTION III PHYSICAL/CHEMICAL CHARACTERISTICS
Boiling Point: OVER 600 F
Vapor Pressure (mm Hg.): @20C:LESS THAN .02mm
Vapor Density (AIR = 1): No Data
Solubility in Water: NEGLIGIBLE
% Volatile / Volume: TRACE
Appearance and Odor: BLACK GREASE, SLIGHT ODOR
pH: No Data
Specific Gravity (H2O = 1): 1.2
Miscellaneous Information
No Corresponding Data In MSDS Provided By Manufacturer
SECTION IV FIRE AND EXPLOSION HAZARD DATA
Flash Point: 370 (COC)
Flammable Limits: NOT ESTABLISHED
Lower Explosive Limit (LEL): No Data
Upper Explosive Limit (UEL): No Data
Extinguishing Media
WATER, FOAM, CARBON DIOXIDE, DRY CHEMICAL
Special Fire Fighting Procedures
IF FIRE INVOLVES SUBSTANTIAL QUANTITIES, SELF CONTAINED BREATHING APPARATUS
SHOULD BE USED DUE TO PRODUCTION OF SMOKE.
Unusual Fire and Explosion Hazards
PRODUCES CONSIDERABLE SMOKE WHEN BURNED.
Product/Trade Name(s): 06-011 GARLOCK NO.2 LUBRICATING COMPOUND CM#700447
Part Number: 700447
MSDS Date: 05/05/86
CAS #: N/A
Category: LUBE OIL
Distributor: GARLOCK INC
Chemical Name: N/A
Formula: N/A
Brief Description: GRAPHITED CUP GREASE
Sun, Jun 17, 2012 9:20 AM
lyoncat
Reply to Jon:
GARLOCK INC
300 ALLING DRIVE
SODUS, NY 14551
(315) 483-6961
pH: No Data
Extinguishing Media
Part Number: 700447
MSDS Date: 05/05/86
CAS #: N/A
Category: LUBE OIL
Chemical Name: N/A
Formula: N/A
Jon,
Thanks for the info on the grease and contacts, i'll see what I can round up from my local dealers with this information! 👍
Thanks again, Mike.
Mon, Jun 18, 2012 8:50 AM
ol Grump
Reply to lyoncat:
Jon,
Thanks again, Mike.
A bunch of years ago a buddy who owned a truck repair shop got me started on Power Punch grease. That's all I have in my shop. .and equipment now.
http://www.powerpunch.biz/msds/msds-mpg.pdf
Mon, Jun 18, 2012 8:56 PM
Jon
Reply to ol Grump:
For graphite impregnated water pump packing you need graphite base grease. It is a wast of time to
use anything else. Jon
Mon, Jun 18, 2012 9:54 PM
Jon
Reply to Jon:
I see that RSC sells a water pump grease. Might be worth try. Jon
http://www.restorationstuff.com/pdf/RestorationSupplyCompany.pdf
Tue, Jun 19, 2012 8:32 AM
Jack
Reply to Jon:
I have a can of old Standard Oil RPM water pump grease. I used the stuff inold Herculese engines. It was old stock when I got the half used can from a service station many years ago. They had it for years before that and never used it because all cars by then had sealed pumps. Thus, I have no idea how old it might be.
It has a soapy feel, is of a light color, and has very little tackiness. It reminds me of half-melted parafin. It is designed to not be displaced by water. If you want to check with Standard-Chevron, I could try to lift a number off of the old can. PM me if you want that number. Sorry, the grease isn't for sale.
Tue, Jun 19, 2012 12:00 PM
Jon
Reply to Jack:
A google search nets too many choices. Jon
http://www.lubriplate.com/webstore/detail.aspx?ID=11
Wed, Jun 20, 2012 7:27 AM
