What do we consider Antique - D4H ? : )
Showing 11 to 18 of 18 results
2
I thought that years ago it was stated that 1960 and older would be considered an antique??
Tue, Mar 31, 2026 9:53 PM
Thank you received: 58
It would be a moving target though I'd think Dan, because in 2060, 1960 will be 100 years ago. I thought it was more about how old something was rather than a set date?
Tue, Mar 31, 2026 9:55 PM
Thank you received: 99
Hi, Folks.
I seem to remember that the criteria was not set at a date but rather at the 'moving' target of 40 years old.
Tue, Mar 31, 2026 9:58 PM
Received an operator's and maintenance manual in the mail and was interested to see that the main transmission is a regular countershaft transmission with six speeds and a "regular" gear lever / shifter, but the direction control is a lever where the powershift control sits, but only has three positions - forward, neutral, and reverse. I'm waiting on the parts catalog to see how that arrangement is set up.
Has anyone operated one of these units and what did you like / dislike about it regardless of transmission type.
Sat, Apr 4, 2026 2:00 PM
Hi, Neil.
I did get to operate a powershift D4D briefly and that had the pretty much standard 3 speeds F/R with neutral right across the front of the shift pattern - never a D4H.
Atta guess and based on what you have divulged about the manual's description, it seems to me that the powershift system in that machine only applies to forward/reverse and that you need to be in neutral there to be able to change the 6-speed transmission.
Does the 'bible' mention anything about a torque converter? If not, then the F/N/R might simply be a directional clutch system.
Sat, Apr 4, 2026 10:20 PM
Yes, as far as I can tell, it's just a regular clutch but I don't know (yet) how the f-n-r is accomplished. It's either going to be a unit behind the clutch, or an assembly in the main transmission. Since it's a separate lever, probably a unit behind the clutch but we'll see once the parts catalog arrives
Sat, Apr 4, 2026 10:45 PM
Hi, Neil.
If itza f/r clutch system, it likely wouldn't need any master clutch> Fiat had something similar on some of their earlier 'alleged' 'powershift' machines which were really justa hydraulically controlled direct drive F/N/R clutch system - CLUNK in/CLUNK out with ZERO feel.
https://www.tractordata.com/industrial-tractors/000/5/9/595-caterpillar-d4h-transmission.html
https://www.scribd.com/document/466450708/cat-D4H-pdf
https://machine.market/specification-847
Look at the description for the direct drive transmission model under "transmission" down to wards the bottom of the spec sheet = might help to explain the F/N/R lever.
Hope it helps.
Just their 0.02.
Sun, Apr 5, 2026 4:56 AM
Hydraulically-actuated master clutch (foot pedal), and a reverser incorporated into the main transmission (regular countershaft transmission where the reverse/forward is accomplished using the output countershaft (third) also incorporating the bevel pinion but operated by a separate lever (not the main speed lever in front of the seat) where the powershift speed/direction control would be located. Narrow gauge 2AC, wide gauge 3AC and 4NK, and powershift 8PB. Skidder I believe is 9PB
Mon, Apr 6, 2026 4:14 PM
2
