Weight Guess
Weight Guess
Showing 1 to 6 of 6 results
Ron
Send a private message to Ron
Weight of D47U track with pads and rails. Pads are 20 inches in width and 34 total.
Sun, Sep 8, 2024 6:02 AM
Thank you received: 54
just the track chains and grousers?
id say about a tonne each side that's a lot of steel
Sun, Sep 8, 2024 6:38 AM
Ron
Reply to trainzkid88:
Yes just chains and grousers.
Sun, Sep 8, 2024 7:34 AM
Thank you received: 62
Reply to Ron:
I hauled D6 9u rails (no grousers), but sprockets and all the bearing for finals the carrier rollers and steering clutches in 3/4 ton pickup. It was a load but no an over load. Did not making the rear end drag. All the way from Miller Track in Modesto to Paso Robles.
Sun, Sep 8, 2024 8:34 AM
josh
Thank you received: 14
Reply to Ray54:
The weight for a 34 link track assembly, 9B2859, with 20 inch shoes in new condition is 1277 lbs.
Sun, Sep 8, 2024 9:27 AM
Ron
Reply to Ron:
Thanks Josh!
Mon, Sep 9, 2024 8:20 AM
Fat Dan
Reply to Ron:
Thanks Josh!
1278 lbs. Wet 🤦‍♂️
Mon, Sep 9, 2024 10:12 AM
