Twenty Two air filter
Showing 1 to 7 of 7 results
bgates
Send a private message to bgates
I need an air filter for my Twenty Two. I have the bottom part, but not the top.
It's the one shaped like a dome, not the one with the jar on the side.
Any ideas?
Mon, May 18, 2009 8:39 AM
powergiant
Send a private message to powergiant
Early ones have a smaller diameter can. Inlet is in different spot in hood also.
Which do you have?
I have a early 22 missing the bottom cup only.
I picked up a complete later 22 air cleaner before I realized they are different, so I have a spare.
Still looking for the early bottom.
Attached is the D2 5J out for a spin.
Tue, May 19, 2009 2:21 AM
bgates
Reply to powergiant:
Which do you have?
Here are two pictures of the base of the filter. I thought this was the older, smaller style that doesn't use the jar.
I would appreciate it if anyone knows where I can get the correct upper section.
Wed, May 20, 2009 5:39 AM
powergiant
Reply to bgates:
That looks like an alien precleaner if I'm mistaken please correct.
I was thinking you were missing part of the oil bath air cleaner below the hood.
Wed, May 20, 2009 5:55 AM
chugwater crawlers
There were three types of tops for the 22 air cleaner.
Post your serial number and I will post the part number for you.
For the part try Jim Zimmerman @641-982-4207.
Wed, May 20, 2009 6:25 AM
powergiant
Reply to chugwater crawlers:
Looks like the top you need is part of 2B4343 (Donaldson X-1360)
Wed, May 20, 2009 12:57 PM
bgates
Serial number on my Twenty Two is: 2F6784SP
Fri, May 22, 2009 12:46 AM
chugwater crawlers
Reply to bgates:
Power Giant posted the correct part number for the air cleaner top for yor machine.
It look like you only need the cap and the screen. The cone assembly appears to be all there.
Cap part number is 9B88803.
Screen part number is 9B8801.
The bolt on top is part number 2F7252.
Just an FYI. The SP in your serial number indicates special parts installed on your machine at the factory
Good luck.
Fri, May 22, 2009 2:15 AM
