Transmission 950B
Transmission 950B
brialin
Send a private message to brialin
Has anyone rebuilt a transmission in Cat 950B loader? Cat says the clutches are gone in 2nd gear. They quoted a price of $11,000 to do a complete rebuild. Do you need any special tools to do this or should I let Cat do it? The machine has 16,500 hours. This is the first major repair. Thinking of rebuilding engine while out since it is starting to use oil and smoke a little. Cat price $13,000. The motor I will do myself.
Brian
Thu, Dec 3, 2009 4:10 AM
bob
Send a private message to bob
You could do it yourself. Just need a clean warm and dry place to work and something to lift with. Get a sheet of plywood /bench top to lay everything out on so you keep track of where it goes. Need to pay close attention to areas that clutch seals run on. Replace every seal inside of it.
Later Bob
Thu, Dec 3, 2009 7:27 AM
