Torque converter getting hot
Showing 1 to 10 of 14 results
clayton
Thank you received: 16
Hi well I installed a torque converter in a D9 19A and it got hot very quickly so took the torque converter cooler out and looks like this hopefully is the problem. I’m assuming it probably hasn’t been cleaned since 1957 lol and the oil cooler as well! I will flush the cooling system and clean pressure test the coolers before installing any other things I should do? Thank you Clayton
Mon, Sep 22, 2025 12:03 AM
Thank you received: 58
Looks nasty Clayton! Should be an easy fix though - fingers crossed!
Mon, Sep 22, 2025 2:09 AM
Thank you received: 52
yeah well theres your problem i would soak it in a cleaning solution rather than mechanical means. see if your local radiator service will hot tank it for you. or make your own hot tank.
a immersion heater in a pot of oil sitting in a bigger vat of cleaning solution
Mon, Sep 22, 2025 9:25 AM
Thank you received: 99
Hi, clayton.
If my memory serves me rightly, those early D9s also had an air cleaner for an air supply to the torque converter for additional coolnig. If there is one, have you checked that to see if it is restricted?
This photo shows the second air cleaner pre-cleaner:
https://i.pinimg.com/originals/77/74/4b/77744b014f7c44a8f1e5148c8d22ce7b.jpg
And this one:
https://live.staticflickr.com/65535/51644554374_48004159b2_z.jpg
Hope it helps. Also mighta bin for the master clutch.
Mon, Sep 22, 2025 12:31 PM
bluox
Thank you received: 11
Hi, clayton.
And this one:
Actually for the brakes.
Bob
Mon, Sep 22, 2025 3:37 PM
clayton
Hi Deas Plant Bluox is correct about the air cleaner it’s for the brake system. Bluox do you have any idea what the temperature difference should be on the torque converter cooler?
Mon, Sep 22, 2025 5:02 PM
bluox
Reply to clayton:
Just off the top of my head maybe 15 degrees.
Do you have a serviceman book?
Bob
Tue, Sep 23, 2025 7:49 AM
clayton
Okay this is the service manual I have it really doesn’t mention much of the torque converter cooler in it.
Tue, Sep 23, 2025 9:07 PM
bluox
Should be a trouble shooting chart in that book.
Your story needs more information.
If it heats without a load that sounds like a bad convertor or a valve problem.
Bob
Wed, Sep 24, 2025 5:05 PM
clayton
There is a troubleshooting section for the torque converter, for overheating in insufficient cooling it says to check the torque converter cooler for plugging which mine was about 85% plugged up! A question I do have is on the oil filter base where the oil cooler fits onto there are metal fittings that have rubber o-rings they are basically just pressed in the oil filter base but there is bolt holes on each side of the flanges which did Not have any bolts in them. Before I reassemble the oil and torque coolers I just want to verify that there isn’t a clamp or hold down missing. In my manual the oil filter base doesnt show any bolt holes on the base. I have attached pictures for a reference thank you Clayton.
Thu, Sep 25, 2025 12:17 PM
clayton
Thu, Sep 25, 2025 12:22 PM
