Tool bar
clayton
Thank you received: 25
Does anyone know if the 8’x4 1/2”x 7 1/2” beam will work with a d47U toolbar bulldozer. I wasnt for sure if it was long enough or not.
Wed, Apr 22, 2026 12:28 AM
Wed, Apr 22, 2026 2:37 AM
Wed, Apr 22, 2026 2:47 AM
clayton
OM so according to this a 8ft bar can be used on the swing around toolbar bulldozer of a d47U, but one would only be able to put attachments on inside of the clamp bars limiting the amount of attachments.
Wed, Apr 22, 2026 10:38 AM
CRS93082
Send a private message to CRS93082
I have one of those shorter toolbars and I measured the width on my 7U and it looks like it should work but as you said you can only run attachments inside the draft arms.
Sat, May 2, 2026 1:57 PM
