Sleeve puller question
Jdz
Send a private message to Jdz
I’m going to be rebuilding a d333 and wanted to find or make a sleeve puller before I start. Do any of you have the specs to build one? I have heard they are a 4.5 inch bore so I should be able to go a little under that but what about the outer diameter of the liner?
Wed, Jul 24, 2019 1:05 PM
JoeG
Send a private message to JoeG
Sounds like you are doing this in frame? Surely you have pulled the pan or the engine side covers try and get a measurement from there, rough number would be good enough. I would say go an 1/8th bigger per side minimum, so 4.75 to start with. I'm guessing you will only need the puller for the first inch anyway, not sure how much sleeve hangs down on this engine. Good luck.
Wed, Jul 24, 2019 4:39 PM
bboaz
Reply to JoeG:
A picture of my sleeve puller. The disk is 5/8 inch thick with a lip on the bottom. Smaller diameter to fit in the sleeve bore and the larger diameter 1/8 inch larger. 3/4 inch all thread with a top bracket made to fit over the outer edges of the sleeve. I use the same tool to install the new sleeves, just turned over as a pusher instead of a puller. Just did a D-318 although I had the motor out of the dozer on an engine stand. Made it much eaisier to be able to turn the motor over to get to the bottom side.
[attachment=54817]20190724_090150.jpg[/attachment][attachment=54818]20190722_162622.jpg[/attachment][attachment=54819]20190722_162540.jpg[/attachment][attachment=54820]20190722_162013.jpg[/attachment]
Wed, Jul 24, 2019 9:25 PM
Hobo groh
Send a private message to Hobo groh
Reply to bboaz:
we had a long bolt and a peice of steel and a slide hammer
Wed, Jul 24, 2019 9:33 PM
Jdz
Reply to Hobo groh:
So far, I just pulled the pan off. I can’t get in there to get a decent measurement...yet. I had a little more than I bargained for in the pan.
Wed, Jul 24, 2019 10:48 PM
Hobo groh
Reply to Jdz:
well at least you will have 1 rebuilt clyinder🤢:frusty:
Wed, Jul 24, 2019 10:52 PM
oldbeek
Reply to Jdz:
That is ugly. Where to begin. Looks like a major overhaul.
Thu, Jul 25, 2019 1:45 AM
Reply to oldbeek:
GEE? I hope you tell us those are spares left over from the last rebuild?
Thu, Jul 25, 2019 9:20 AM
Jdz
Reply to drujinin:
I was surprised when I pulled the pan and seen all that. That is one of the worst I’ve opened up. Usually it’s just bearings and call it good. Something tells me I’m not going to be quite that lucky this time😂. I am going to pull the engine, I know I will have to grind the crank. I’m just hoping all those pieces came out of the same cylinder🤞
Thu, Jul 25, 2019 11:10 AM
