Rusty Iron?
Rusty Iron?
Showing 1 to 6 of 6 results
James Hayes
Send a private message to James Hayes
Gentlemen,
I know this isn't a CAT, but what do you reckon it is?
Thanks,James [attachment=8808]old tractor.jpg[/attachment]
Sat, Apr 23, 2011 10:17 PM
D6c10K
Send a private message to D6c10K
Farmall....can't tell for sure on Model, maybe an F30 from the oil filtler location.
Looks pretty complete and has a can on the exhaust so it might be ok.
Not many of them still have the steel wheels...most had the spokes cut and rubber tire rims welded on. (I've got an old fixture at home designed to do just that)
Sat, Apr 23, 2011 10:46 PM
hiwide15
Send a private message to hiwide15
Reply to D6c10K:
worth looking into for sake of saving anything you can these days
Ron Meeder
Sun, Apr 24, 2011 5:52 AM
Paul L.
Send a private message to Paul L.
Reply to hiwide15:
Ron Meeder
Looks like a Farmall Regular to me.
Sun, Apr 24, 2011 9:56 AM
zootownjeepguy
Reply to Paul L.:
The Farmall Regular had open steering gears. My buddy has one (he's a John Deere guy. That regular could be mine. Nah, I have too many projects already:lol😊.
Rich Salvaggio
D2 5U9917
Sun, Apr 24, 2011 10:44 AM
Toolbox
Send a private message to Toolbox
Reply to zootownjeepguy:
That's a "duck bill" F-30. You can tell by the shape of the steering gear and the way the rear wheels bolt on. That would make it an early one. I haven't seen very many of those around.
Sun, Apr 24, 2011 8:41 PM
YeLLoIrOn
Send a private message to YeLLoIrOn
Reply to Toolbox:
definently a duckbill f-30. '32 to early '34 you can tell by the depth of the fuel tank, it comes down even with the oil filter base on the block- F20's are about half way down the oil filter its self. Also you cant see the nut on the rear hub assembly but the bolts are the bigger style like an F30, F20's are half inch.
The duckbill F30's and F20's are just essentially a regular steering design with a gear case instead of open. Also if it has steel on the front i've seen those wheels alone bring $750 for a nice set.
The duckbill F20's use regular steering shaft, I found this out the hard way!:jaw:[attachment=8810]Picture 398.jpg[/attachment]
Mon, Apr 25, 2011 12:10 AM
