Rusty D 2
Rusty D 2
Showing 1 to 10 of 11 results
d4angelo
Thank you received: 7
Hi guys, I am helping a buddy work on his D2. It was left outside in the rain last year and every compartment is seized up. I want to pour something in both steering clutch compartments to free them up. What works? I have heard about Kerosene but it is hard to find around here. Some options might be Diesel fuel or vinegar. Any thoughts?
Fri, Sep 27, 2024 11:35 PM
clayton
Thank you received: 25
Put diesel fuel in the steering clutch compartments and let it sit for a few days then operate it and see if they freed up may have to work it hard for a bit to get them freed up.
Sat, Sep 28, 2024 3:23 AM
Reply to clayton:
I used diesel fuel in my steering clutches and it freed up--chained it to a tree and by alternating forward and reverse they became loose
Sat, Sep 28, 2024 3:44 AM
Thank you received: 287
Reply to dpendzic:
Yes Ang. Start it up and work it back and forth after it had a chance to soak. Pictures please, or it didn't happen as some would say...JM
Sat, Sep 28, 2024 9:10 AM
d4angelo
Thanks for the help guys. Pictures to follow JM
Sat, Sep 28, 2024 9:37 PM
d4angelo
Reply to d4angelo:
More on the rusty D2. Engine was separated from machine and I was able to release the main clutch lever. I removed the clutch and found both sides of the pressure plate badly rusted and pitted. I was able to use a flap disc to remove the surface rust. I used a small flat blade screwdriver to clean the lines across the fiber disc. My next hurdle is to find out why the pony piƱon lever will not move. It is frozen in place and will not budge. Any thoughts? I really don't want to remove the pony from the diesel main if I don't have to. Suggestions please!
Mon, Sep 30, 2024 11:53 AM
gemdozer
Reply to d4angelo:
The pine on bar could be ben or linkage is missing lubrification and am not sure if he has a greace fitting in bottom
Mon, Sep 30, 2024 5:54 PM
Thank you received: 78
Reply to gemdozer:
Hi Angelo!, does the pinion engage if you push on the end by hand, ignoring the lever and the arm that engages it? If it does, then I'd say the lever shaft, or the arm in the slide is seized. What you could do is manually engage the pinion, apply some mild heat and penetrating oil, then lightly tap on the lever and/or arm and see if you can initiate some movement. If you can, then just work it/them back and forth applying more oil and it should loosen up.
Mon, Sep 30, 2024 7:27 PM
d4angelo
Thanks for the help guys. Neil, I don't really want to beat on the end of the pinon shaft because the brake is on the end of that. Keep in mind, nothing moves! Removing the pony might be easier with the main diesel removed from the chassis.
Tue, Oct 1, 2024 5:13 AM
Reply to d4angelo:
Oh I see, not even any movement? I think you're right then Angelo, remove and disassemble sounds like the right approach
Tue, Oct 1, 2024 7:16 PM
SoCalCatMan
Send a private message to SoCalCatMan
Reply to d4angelo:
Good to see AGSEM working on something yellow. Next up is the Holt Harvester !
Sun, Oct 6, 2024 12:06 AM
