ring source
ring source
rturn3060
Send a private message to rturn3060
Just received ring set for my Cat 35 +.125 oversize ( 5" bore by 3/16 rings) in good, order and priced right from Total Seal Phoenix Arizona 623 587 7400
Mon, Mar 16, 2020 11:58 AM
D4Jim
Thanks for the info. Do they make custom ring sets or modify some "close" rings? Got a couple small engines that need special rings as the pistons and the bore looks pretty good.
A few years back I was overhauling a small block Chevy V-8 bored 1/16 over and found out it took the same rings as a '53 DeSoto without having to grind the ends. Just pure luck.
Cats Forever
Tue, Mar 17, 2020 9:31 AM
BobPV15
Send a private message to BobPV15
Reply to D4Jim:
Google "Otto gas engine works" They make rings from 5/8" diameter to 56" That should cover most things!!
Tue, Mar 17, 2020 11:40 AM
Mike Meyer
Thank you received: 6
Reply to BobPV15:
I bought a set of rings from Otto last year for my 30, included some oversize, price was around $US240 from memory, I haven't fitted them yet but Dave there was good to deal with.
Wed, Mar 18, 2020 2:11 AM
