RD4 pony starting issue
Showing 1 to 10 of 40 results
FLDrew91
Send a private message to FLDrew91
Good evening fellas, I’m having trouble getting my RD4 4G pony to start. It ran fine last week but we’ve had some heavy rains the last several days and when I tried starting it yesterday it ran for a bit but acted like it couldn’t get up to full speed and stalled. The pony has been rebuilt along with the carb and I put new points and a condenser in the mag (wico).
I put fresh gas in the tank, checked for fuel flow and pulled the bowl off for a cleaning. It gets spark and it’ll cough over a few times but doesn’t run. I did get it to run for about a minute with the throttle half way and almost full choke. Any ideas what the problem could be?
Current project: 1936 RD4
Wed, Aug 22, 2018 8:46 AM
STEPHEN
Water in the fuel? I recently had the same situation after arrival at a show, found some water in the fuel. I noticed that water will mix with rust particles and go right into the carb instead of settling in the jar. I removed the carb bowl and cleaned thoroughly plus installed a new zenith fuel valve on the tank. The pony hasn't run better in years and no more excessive choking.
That is the short story, I left out the cursing, moaning, rope pulling, and false leads.
Wed, Aug 22, 2018 1:47 PM
STEPHEN
Reply to STEPHEN:
Have you removed the mag cap and checked for tracking, moisture, etc? Put a low setting hair dryer on it for good measure.
I have also seen where flooding can carry carbon into the plug and short it.
Wed, Aug 22, 2018 1:51 PM
FLDrew91
Reply to STEPHEN:
Thanks for the replies. I emptied the gas tank, put in fresh fuel and cleaned the sediment bowl and screen. I pulled the mag cap off, checked the points and the rotor all correct. I put a heat gun on it at the lowest settings and dried it out. Now it won’t even bark. It was puttering this morning before I messed with the mag and still acted like it was either missing or fuel deprived. I manipulated the governor linkage while it was running and it wouldn’t go past half throttle. I serviced the governor before reinstalling and it worked fine. I’m think now I might need to a new mag rotor and see if the governor is stuck.
Any other ideas are welcome.
Thu, Aug 23, 2018 12:10 AM
STEPHEN
Reply to FLDrew91:
Mag out of time?
Thu, Aug 23, 2018 1:33 AM
FLDrew91
Reply to STEPHEN:
Mag out of time?
I don’t think so. I marked the gear and rotor when I took the cap off and I retimed it the last time I took the mag off. I think the rotor isn’t making good contact with the cap and causing no spark now.
Thu, Aug 23, 2018 1:38 AM
STEPHEN
Reply to FLDrew91:
The rotor is brushed or jump spark?
Thu, Aug 23, 2018 2:04 AM
FLDrew91
Reply to STEPHEN:
Jump spark. I’m wondering if the cap and rotor might be worn out.
Thu, Aug 23, 2018 2:11 AM
rax200
Reply to FLDrew91:
Hi FLDrew91,
Had the same issue one day, did all the same things, found out when i put the leads back on i put them on backwards, simple mistake but can be very frustrating.
Regards
Thu, Aug 23, 2018 3:20 AM
FLDrew91
Reply to rax200:
Hi FLDrew91,
Regards
[quote="rax200"]Hi FLDrew91,
Regards[/quote]
Plug wires? I’ve done that before and figured out the issue pretty quick. I double checked this time too and they are correct. Its definitely very frustrating... worked a few days ago, now it’s showing it’s a$$ lol
Thu, Aug 23, 2018 3:36 AM
catfan
Send a private message to catfan
Reply to FLDrew91:
Regards[/quote]
I've had that happen also and it turned out to be a hairline crack in the Magneto cap
Fri, Aug 24, 2018 11:29 PM
