Rare tractor
Rare tractor
Showing 1 to 10 of 10 results
QuAD
Has anyone ever seen this machine.
Seems that it is used to harvest plants.
Wed, Jul 18, 2018 9:48 PM
Online
Thank you received: 227
There have been several modifications to Caterpillar for the purpose of lifting nursery stock.
Most of them are "raised" and use some sort of "slip plow".
This appears to be one of them.
cts
Wed, Jul 18, 2018 10:04 PM
jstandle
Send a private message to jstandle
Reply to ctsnowfighter:
cts
Looks like an RD4 with custom pads, raised fenders and relocated fuel tank. It doesn't really look to me like the rest of the machine is different.
Jordan
Wed, Jul 18, 2018 10:33 PM
Online
Reply to jstandle:
Jordan
http://www.acmoc.org/bb/showthread.php?9285-Custom-High-Crop-Crawler/page2
Necessity is the mother of invention --
California Agriculture - changed many aspects of what today we consider normal. Adaptations have indeed changed our world, all born from the origins here based upon the special needs and demands.
The highly specialized needs of "lifting" nursery stock for replanting resulted in these Caterpillars modified to extreme high clearances, still providing for the flotation and traction needs to pull a "slip plow".
CTS
Wed, Jul 18, 2018 11:55 PM
Thank you received: 287
CTS
Here is one that IronAppraiser and OIH shared photos of awhile back.
Thu, Jul 19, 2018 3:25 AM
FatCAT
Send a private message to FatCAT
Hey Juiceman if they ever had a mud bog at a tractor show that might come in handy for you lol hahaha
Thu, Jul 19, 2018 11:54 PM
Online
Reply to FatCAT:
FatCat -- the "Juiceman" would just re-incarnate the blocks that were used for so many years in the rice fields.
Put 'em on a Sixty and go where rest would just be mired to the bitter ends.
Fri, Jul 20, 2018 2:36 AM
Some off color high clearance.
Fri, Jul 20, 2018 6:45 AM
Oil Slick
Would the track extensions change his gear ratio? I wouldn’t think so, just change the speed around the idler and sprocket.
Sat, Jul 21, 2018 4:33 AM
Online
Reply to Oil Slick:
Length of the track would make no difference in the ground speed - that is determined by the speed (rpm from flywheel -transmission - rear end and the final drives) of the driving sprocket and the diameter of the sprocket.
Track is much different than tires where change in diameter changes the speeds.
Sat, Jul 21, 2018 4:46 AM
bvandragt
Send a private message to bvandragt
Here's a video of another high clearance crawler. A John Deere BO Lindeman with pad spacers.
https://youtu.be/TsLzNqOrIFo
Brian
Sat, Jul 21, 2018 6:08 AM
