Question about Hyster towing winch for Cat 22?
Showing 1 to 9 of 9 results
Peter C
Send a private message to Peter C
Hi, I'm trying to take a Hyster towing winch apart to get it into operating condition and have a few of questions. I'm now trying to remove the cable drum from the metal casing.
1. Does the chain drive have a master link that I can remove? If not, then I'm guessing that I have to remove about 6-8 bolts that are sort of visible with the red arrows and accessed through the hole in the casing circled in red.
2. Does anyone have the parts and the operator's manuals and would be willing to sell or scan a page or two showing how the sprocket is attached to the cable drum??
Pete
Fri, Feb 2, 2024 4:26 AM
Thank you received: 78
I don't Peter, but boy am I interested in seeing LOTS of detailed pictures as you disassemble it.
Fri, Feb 2, 2024 9:43 PM
josh
Thank you received: 14
The picture you have posted about the features of the winch are much better than the parts and installation manual. There is no master link in the parts list, just chain, you will have to go over the chain and see, also it looks like you can see the cap screws that hold the sprocket onto the drum in your picture, but not in the parts book.
Fri, Feb 2, 2024 11:15 PM
Online
Thank you received: 227
Reply to josh:
Roller chain without master link?
I do not ever recall working on a roller chain without master link.
CTS
Sat, Feb 3, 2024 12:27 AM
daron
Reply to ctsnowfighter:
CTS
[quote="ctsnowfighter post=254481 userid=9709"]Roller chain without master link?
CTS
How about automotive timing chains?
Daron
(I did get the set from Rob Mcleary.  Nice.)
 [/quote]
Sat, Feb 3, 2024 3:59 AM
Online
Reply to daron:
CTS
Daron
 [/quote]
Yes Daron,
Timing Chains, Chain Saw Chains, Bicycle Chains, to name a few that did not have master links per say.
There is always an exception.
CTS
Sat, Feb 3, 2024 4:13 AM
mog5858
Yes Daron,
CTS
very neat. but how are you going about reversing the drum? or is it just power in and the dog it out for free spool? simple but sometimes them dog to like to shift especially under load.
thanks for sharing.
Sat, Feb 3, 2024 5:13 AM
Peter C
Reply to mog5858:
thanks for sharing.
Thanks every one for all of the input.
Josh and every one, I did find a master link on the chain AFTER I got it all apart and cleaned up. Here are some pictures.
mog5858: Yes, there is no reversing of  the drum. It is free wheel out but the brake is missing so it will only be to lengthen the cable. Here is the sliding clutch for free spooling:    [attachment=75170]IMG_3176.JPG[/attachment]
Neil, here are pictures. I use them for reassembly hoping every thing was correct when I disassembled it:  [attachment=75177]winched removed (1).JPG[/attachment] [attachment=75173]exterior removed (3).JPG[/attachment] [attachment=75179]interior (3).JPG[/attachment] [attachment=75178]interior (5).JPG[/attachment] [attachment=75175]IMG_3181.JPG[/attachment] [attachment=75176]IMG_3167.JPG[/attachment] [attachment=75171]IMG_E3169.JPG[/attachment] [attachment=75174]IMG_E3171.JPG[/attachment]
Sun, Feb 4, 2024 11:45 PM
Thank you received: 54
Reply to Peter C:
that is normal duplex drive chain it will have a joiner link they can be "fun" as there is a fish plate in the middle too.
yes while many timing chains dont have a joining link some do. ive worked on stuff that did. saw chains and bicycle chains use a chain breaker press and a rivet spinner to break and make the chain.
Tue, Feb 6, 2024 2:53 PM
mog5858
Reply to trainzkid88:
thanks for the info. that really is a very simple but effective way to to make a dog clutch I like it.
Thu, Feb 8, 2024 5:31 AM
