pup motor specs.
pup motor specs.
firekat
Send a private message to firekat
Hello
I haven't gotten my books. So I need some specs on 8R,2U,3T pup motor.
Standard Bore
" " Crankshaft Mains/Rods
what can the Mains/Rods get turned down too also.
Any other specs would be useful.
thanks
firecat
Wed, Apr 2, 2008 12:28 PM
SJ
Send a private message to SJ
Bore is 3.628"-3.629" X 4" stroke and crank is mains 2.125" and conn. rods are 1.999" and valves are set .008" hot so add about .002" more for cold setting. I don,t have a parts book on the undersize bearings and can,t remember what is available but .020" under sounds about right. There may even be .030" under available but not sure without a book. If you need any other spec. I have a factory sheet here on it and other older Cat engines starting and diesel.
Wed, Apr 2, 2008 6:36 PM
